Porting LS6 Intake
Old Jun 19, 2008 | 02:22 PM
disavowed10's Avatar
Default Porting LS6 Intake
Is it worth it?
Here's the situation. I work at an aerospace machining company and there are tons of machines here. One of the guys here suggested that I should port the LS6 intake. He would do it for me.
How far can i port it if so? And any suggestions? Precautions?
AND I just found out we have a sand blaster! COOL! One of the guys is sand-blasting my new ported Throttle Body as we speak!
Old Jun 19, 2008 | 03:43 PM
or boring it out abit?
just the inlet
Old Jun 19, 2008 | 05:11 PM
stevied916's Avatar
you can port match the runners and bore the inlet to the size of the tb. Other than that I wouldnt do anything else
Old Jun 19, 2008 | 06:04 PM
JBIRD02's Avatar
Yeah, this is all I was told could be done too. no real porting, just matching up the runners. TPIS can do a 90mm LS6 though. They are a sponsor on here.
Old Jun 20, 2008 | 12:49 AM
http://www.lingenfelter.com/store/100-191.html
is it worth it? trade in my LS6 for $500? and pay the difference? i originally payed $275. The FAST 90MM is $800+
So 275 + 350 = $625 which is cheaper
Old Jun 20, 2008 | 02:29 AM
180ls1's Avatar
you only need a fast 90 on a car with a huge cam or a h/c car.
Old Jun 20, 2008 | 02:46 AM
1_bad_TA's Avatar
or you can do an ls2 intake
Old Jun 20, 2008 | 08:57 AM
so I cant just install the LS6 90MM intake manifold without tuning? i plan on getting a nice cam. some suggested a 224 which i heard is the biggest smog legal cam.
i will end up getting a 90MM throttle body aswell. any suggestions?? and will i have to tune if i only have the ls6 90mm and a 90mm TB?
Old Jun 20, 2008 | 09:18 AM
LSWONGTO's Avatar
How much do people sell them for. I plan on selling mine when I get back to the "world" the states once the car gets the heads and fast in.
Old Jun 20, 2008 | 11:27 AM
sschkade's Avatar
LS6 flows better than the LS2.
Old Jun 20, 2008 | 01:29 PM
will i have to tune if i only get the ls6 90mm and a 90mm TB and everything else stock?
Old Jun 20, 2008 | 02:14 PM
bczee's Avatar
Question Are you talking about a stock/OEM LS6 intake ?.. are they not only 78mm ? to match the Throttle Body. Or are you boring the LS6 opening to 90mm?
Old Jun 20, 2008 | 03:00 PM
yeah im getting the TPIS 90MM LS6 intake
http://www.tpis.com/index.php?module...ed+LS6+Intakes
tune or not to tune
Old Jun 20, 2008 | 04:49 PM
Funkster's Avatar
You might be able to get away without a tune. I would just for the safety in it though.
Old Jun 20, 2008 | 07:47 PM
im just being cautious cause if you think about it im going to be getting aton more air in there and there probably wont be enough fuel being fed so i might burn valves or sumthing..
Old Jun 20, 2008 | 09:32 PM
Paint_It_Black's Avatar
it does? what's your source?
Old Jun 20, 2008 | 09:39 PM
Old Jun 23, 2008 | 05:03 AM
MNR-0's Avatar
News to me...
Old Jun 23, 2008 | 05:55 AM
95 Z28's Avatar
LS6 does indeed flow better. There's been numerous real world tests that proove it too. I just did a quick search and found this test, there's others out there...
http://www.vetteweb.com/tech/vemp_06.../photo_13.html
Old Jun 26, 2008 | 01:12 AM
sschkade's Avatar
Arrow
My source is a book... "Dyno-Proven GM LS1 Thru LS7 Performance Parts," not to mention the countless "online" sources like the one posted above ^^^ (thanks 95 Z28). ...and the fact that it's been discussed here on LS1Tech on several occasions (search)!
Overall, just because the LS2 has a 90mm snout - doesn't necessarily make it a better intake (e.g. take into account the plenums and runners).
Stock for stock, LS2 vs LS6 - the LS6 wins any day IMO.
Now porting them both and testing them, I've got no idea.
However, from what I hear, you can't really "port" an LS6 intake all that much.
In regards to opening the snout of a LS6 intake to 90mm, I don't think the gains are worth it.
...But if you're gonna pay someone to do the port work or open the snout - why not just splurge for a FAST 92mm?!
Ultimately, 1_bad_TA suggested a LS2 intake over a LS6 intake... and I'd say that would be a waste of money.
Just my $0.02! Hope this helps.
