gmpp carb intake overkill on cam&spray ls1?
Old 06-26-2008, 07:43 AM
uscg02ws6's Avatar
Default gmpp carb intake overkill on cam&spray ls1?
i have an ms4 and 150 wet kit going on my car. The motor is a 2002 so it came with the ls6 intake, besides that there is a lid, LTs, and LM1. I want to know if it is going to be overkill to go with a GMPP carb intake with Dave's elbow and a 1 inch n20 plate. In the future I plane on getting heads and a lq9 block and spraying a 200 shot.
Old 06-26-2008, 07:47 AM
Internet Mechanic
BlackScreaminMachine's Avatar
If it car has stock heads for now I would say yes.
Old 06-26-2008, 08:16 AM
uscg02ws6's Avatar
for now it is stock heads. im not even sure I want to go aftermarket heads when I I get the lq9. my motor has 77k on it now and with the lq9 I will basically have a new motor and it will also be strong enough for at 200 shot and be a few cubes bigger.
Old 06-26-2008, 08:50 AM
s346k's Avatar
will that fit under the cowl? the gmpp carbed style intake and 1" spacer? either way, i don't think it's overkill. it will definately push your powerband UP and shiftpoint around 7k rpm i'd guess. you will make more power than an ls6 intake for sure.
Old 06-26-2008, 09:41 AM
slt200mph's Avatar
It will not fit under your cowl ... You are going to have to do some cutting on the car to get it to fit..a friend of mine just did one and some surgery was required to get it to fit..good luck with it...
Old 06-26-2008, 09:49 AM
uscg02ws6's Avatar
From what I have read the GMPP is shorter then the vic jr. and Dave's elbow needs a 1 inch spacer becaz it was designed for the vic jr. this is y I am looking at this set up. I think the looks of the install with a crab plate with be so much cleaner and will also leave room for improvement when I move up to a set of heads and a new block. I also think the carb plate will be substantially more efficient then a shark nozzle or Dave's tb plate when i going to eventually bump up to a 200 shot
Old 06-26-2008, 10:01 AM
SMAX's Avatar
Both intakes are made to accept the same type 4150 carb so needing a 1" spacer for one and not the other makes no sense.
Old 06-26-2008, 11:03 AM
uscg02ws6's Avatar
the carb flange is the same but i believe the height of the intake is not. the way the elbow is shaped is so that u do not need to cut the cowl with the vic jr. but the with the shorter gmpp u can fit a n2o plate with out cuting the cowl
Old 06-26-2008, 11:04 AM
slt200mph's Avatar
Originally Posted by uscg02ws6
From what I have read the GMPP is shorter then the vic jr. and Dave's elbow needs a 1 inch spacer becaz it was designed for the vic jr. this is y I am looking at this set up. I think the looks of the install with a crab plate with be so much cleaner and will also leave room for improvement when I move up to a set of heads and a new block. I also think the crab plate will be substantially more efficient then a shark nozzle or Dave's tb plate when i going to eventually bump up to a 200 shot
Like I said get your sawzall out and prepare to do some cutting.
PS Proof reading your post is your friend ie "crab plate" ??..you probably mean carb plate ... short for carburetor plate.
Old 06-26-2008, 11:12 AM
uscg02ws6's Avatar
https://ls1tech.com/forums/showthrea...mpp+dave+elbow
^^talks about the height dif in the two intakes and running the spacer
^^^similar set up I want for the future just with out the l92 heads caz I here they match up poorly with the ms4.
how much cutting is going to be needed im kind of afraid of hacking my car up???
Old 06-26-2008, 11:16 AM
uscg02ws6's Avatar
and yes sorry about my spelling i did mean carb plate..... That's y i don't post much caz I don't like getting flamed for my grammar and spell so most of the time its ezer to just search
Old 06-26-2008, 11:37 AM
slt200mph's Avatar
I'll try and find some pics of it for ya.
Old 06-26-2008, 12:13 PM
s346k's Avatar
any way you can run the gmpp intake, that plate kit, and just throw a carb style tb on top? that would be more cost effective and generate more power, as well.
Old 06-26-2008, 12:17 PM
uscg02ws6's Avatar
well i could but this is a going to be a street car and with a 4 barrel tb there is no way to get a filter on it or keep my maf
Old 06-26-2008, 12:39 PM
s346k's Avatar
meh. just keep an eye on the oil and you'll be fine. you'll blow it up long before driving it around with no air filter will cause enough damage to be a problem.
sd tuning is your friend with a setup like this, also.
Old 06-26-2008, 02:37 PM
uscg02ws6's Avatar
id like to keep some kind of gas mileage so sd tuning is prob not going to be the best bet i kno its not going to be good on gas but id like to keep as some what reasonable
Old 06-26-2008, 03:08 PM
Pro52R's Avatar
Not to be a dick, but are you mildly retarded? Or ignorant?
Old 06-26-2008, 03:15 PM
s346k's Avatar
what difference will that make? 1-2 mpg? if that much even. are you serious? you have a 240* duration cam, single plane intake, and a 150 shot. you're concerned about gas mileage? you sir, are comical.
Old 06-26-2008, 03:16 PM
uscg02ws6's Avatar
If u don’t want to be a dick then y the hell do u even have to post ur input? if u don't want to read my post then the back button is on the top left of the page and ur more then welcome to leave.
Old 06-26-2008, 03:17 PM
uscg02ws6's Avatar
I thought that with an sd tune ur looking at around 5 to 10 mpg.
Quick Reply: gmpp carb intake overkill on cam&spray ls1?
