which heads
Old Jul 4, 2008 | 11:59 AM
1fastmofo's Avatar
Default which heads
what is the best head for the money. I have read up on the flow numbers and understand what they are. I understand that usually you get what you pay for and that all your power is in your heads so If im gonna try and go big here is the component to do so. I guess what Im asking is for example if a set of afr's on average will only make me say 15 more horses than a set of patriots and the patriots are half the price I would go with the patriots.
Car is a 93 rx7 ls1 4l60e cam will be torquer v3 intake will be ls6 and stall will be yank 3400 4:10 rear gear curb weight approx 2600
Old Jul 4, 2008 | 01:49 PM
fuzzyjk's Avatar
TSP 5.3 Stage 2.5 or the TEA, both seem to be big bang for the buck
Old Jul 4, 2008 | 03:06 PM
LS1C5Vette's Avatar
TEA stg 1.5 5.3l heads are badass
Old Jul 4, 2008 | 06:58 PM
LSWNDR's Avatar
5.3's rock for sure but LS6 are awsome to depends what you have th spend but if you wana do it right hit up www.totalengineairflow.com because they know flow!
Old Jul 4, 2008 | 07:24 PM
BES Stroked Nova's Avatar
I would try the new revised PRC stage 1.0 LS6 heads, with the stock valve size it give a little more needed room for the PTV clearance
Old Jul 6, 2008 | 01:08 PM
1fastmofo's Avatar
which is better ls6 or 5.3 heads
Old Jul 6, 2008 | 01:16 PM
2000_SS's Avatar
best heads = best heads for YOUR SETUP. get with one of our sponsors and see what kinda of flow you need to take advantage of your cam's valve events. FWIW, my car dynoed 452rwhp with a 231/237 cam & TSP stage 2.5 5.3 heads....through a 9". it's all in the combo and how it works together. you'll notice a lot of big-donkey-dick cams don't make the kind of power i was in similar, or arguably better built, setups. but you're right, you will get what you pay for. keep your eye on the 'for sale' section on here and you might find a good deal.
