should i install arp rod bolts on my 80 k motor?
I am putting a head/cam package on my motor this weekend and have the pan off anyway.
should I put the arp rod bolts on that I have or willl they screw something up?
if I don't do them now I can use them on my 383 next winter, so its not a loss.
I have just heard that the rods will elongate with new rod bolts.
if I do install them should I do the stretch method that is sugested with the bolts?
Kind of the same question here. I was going to buy and install ARP rod bolts on my 34K motor since it's out of the car right now and I plan on installing a nasty cam, heads, intake, oil pump, LS2 timing chain etc etc
A guy I know suggested against doing it with the motor together.
Instead, he suggested that I pull the crank and have the rods re-sized and the ARP bolts installed then install new rod and main bearings while I'm at it.
Then I figured I might as well hone it and install hellfire rings while I'm at it.
I'm just not feeling like tearing apart this damn engine.
I wouldnt bother replacing rod bolts unless the motor was coming out for a rebuild.
And since when do you take the pan off for a head/cam swap? Is there another reason the pan is off?
And the motor got a new oil pump/timing gears/seals.
I read the term resized in this thread...is it possible to resize a fractured cap rod design? I know on conventional rods the bolts are what positively registers and locates the cap on the rod meaning every time new bolts are installed the rods had to be resized. I thought the unique fracture line which positively and correctly registers the cap on the rod made resizing unnecessary and impossible even if changing bolts. If a fractured cap rod is stretched or egg-shaped it must be replaced.
I know of many local cars that have replaced the rod bolts on an LS1 (most of them early ones) without issues. I think this goes back to a search issue...something tells me this has been covered before.
