Heads worth swap?? 806's for 241's??
Hello all, I got a 98z28 A4 with 806 casting heads. When I install a new intake (probably LS6) I was thinking about putting the 241's on. Is this even worth my effort?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
No, the ports on all LS1 heads are the same. The only differences are the casting methods used. The later castings used a method that produced a smoother port. Once aftermarket porting has been done they are equal performance wise.
