spun bearing ?
Old Jul 6, 2008 | 04:22 PM
crainholio's Avatar
Originally Posted by Paint_It_Black
They probably run tolerances loose enough for 15w50 though.
When you learn the difference between "tolerance" and "clearance" you'll sound way more credible.
Old Jul 6, 2008 | 04:58 PM
brad8266's Avatar
Originally Posted by crainholio
Your posts are kind of amusing when read in series.
Your point is???
I gave two scenarios that are plausible with the rod bearing being the more likely of the two.
Old Jul 6, 2008 | 05:01 PM
crainholio's Avatar
Originally Posted by brad8266
Your point is???
If it's a spun rod bearing, where did the aluminum shavings in his oil come from?
Old Jul 6, 2008 | 05:02 PM
Paint_It_Black's Avatar
That's what I meant, clearance. I still measure it the same way. I know what I'm looking for.
Like today when I was golfing this morning. I hit a drive that hooked left. My friend said I almost sliced it into the woods. A slice for a right handed player would be a ball that curves to the far right of the target, not the left.. but I didn't hang him up for it, I knew what he meant.
Old Jul 6, 2008 | 05:11 PM
brad8266's Avatar
Saying it is aluminum is also assuming, if these shavings were found clinging on the magnetic drain plug which I would suspect is the case since the engine is not torn apart yet then it probably is steel bearing material.
Aluminum is non-magnetic which of course you know being a metal expert.
brad8266's Avatar
Nice metaphor.
Old Jul 6, 2008 | 05:24 PM
crainholio's Avatar
You measure tolerance with a micrometer? How's that work?
On second thought forget it, please don't try to think up another answer...
Old Jul 6, 2008 | 05:29 PM
crainholio's Avatar
The guy said there was aluminum in his oil.
I tend to believe people know what they're talking about until they prove otherwise. As in your case. Try learning the difference between magnetism and ferrous metal content. (hint: your steel bearing shells won't attract ferrous metal, will they?
Old Jul 6, 2008 | 05:42 PM
brad8266's Avatar
The guy also doesnt know if he should get his motor machined after a spun bearing so I would say its safe to assume he might not know the difference between aluminum and steel shavings on an oil drain plug. I dont say that to be offensive so no pun intented.
Most of time you spin a bearing in these motors the bearing material is in the oil and most of time its a rod bearing. Freshen the crank and rebuild, plain and simple.
Old Jul 6, 2008 | 05:49 PM
No no no.. I measure CLEARANCE... good lord.. Crainholio, will you please forgive my improper diction? It's sunday, and my brain gets the day off.
Old Jul 6, 2008 | 10:20 PM
LS1inNM's Avatar
sorry for the feuding in here... after reading all the post.. it is metal that was in the oil cause like stated in here a few post earlier... the shavings were on the magnetic plug.. so these shavings are more likely from what... the bearing or..? On a good note.. i found a ls1 guy here in nm that is gonna help me out on my car...not the wait begins for the money till aug
Old Jul 7, 2008 | 10:34 AM
  #32
crainholio's Avatar
If the debris is attracted to your magnetic plug, they're not aluminum. This might be good news.
It's possible that you've had a lifter fail and score up the cam, both are made of ferrous metal which would show up on your magnet. Potentially fixable in-car depending on the failure, but you'd be pulling the heads to inspect for the condition.
