quest for 600hp
Old Jul 14, 2008 | 12:41 PM
melon07's Avatar
Default quest for 600hp
just bought a LS1 for $200 bucks and i'm looking to get 600 horse out of it. I don't know much about ls1 yet and was wondering what some options are. Trying to keep it on a lower budget (yea right) so anything that'll pull these numbers would be great. (nitrous, blower, etc.) thanks for the help
Old Jul 14, 2008 | 01:10 PM
02WS6_TA's Avatar
Well you can run the boost but you may run into some issues with the internals (not to familiar with FI). I would probably go with a good head, intake, and cam setup to get about 450hp-470hp then hit it with a 150 shot with all of the supporting mods. Good luck on your build
Old Jul 14, 2008 | 01:17 PM
bigti99a's Avatar
boost or juice? i would think n20 would be a little less cash. but both arn't going to be cheap. and most people max at 550-600 on stock internals and that is really pushing the limit of the bottom end. check out th FI section though there are plenty of guys in that area of power.
Old Jul 14, 2008 | 01:19 PM
nddragon01's Avatar
Good luck keeping it cheap...report back when you finally get to 600hp with the total damage to your wallet.
Old Jul 14, 2008 | 01:28 PM
teke184's Avatar
soo...
rear wheel or flywheel??
if the engine is out, swap out the bottom end for a middle of the road setup (possibly even bore/stroke to a 382ci), run some dished pistons, budget ported 72cc truck heads, FAST intake and a custom FI cam.
then throw on the supercharger...either a maggie or a good sized procharger.
i would think $10K should get you the 600hp you want and still be pretty reliable.
Old Jul 14, 2008 | 03:17 PM
nddragon01's Avatar
If you want the car to be drivable and not just sit in your garage with a 600hp sign on it, don't forget the rear end ($3K) and upgrading your suspension, clutch/flywheel, etc...
Old Jul 14, 2008 | 03:56 PM
imma_stocker's Avatar
add fuel, tune, clutch, tires, brakes, and gauges.
Old Jul 14, 2008 | 09:24 PM
nddragon01's Avatar
Ah, yes. Keep adding to the financial vacuum...
Old Jul 15, 2008 | 03:40 AM
LSWNDR's Avatar
scroll up on the threads and read mine about N/A 346 unrealistic to make 500 with H/C
Old Jul 16, 2008 | 12:21 AM
melon07's Avatar
thanks for the tips guys.... might just put a big block in after all
