shiming the oil pump spring
Old Jul 14, 2008 | 04:28 PM
daniel6718's Avatar
Default shiming the oil pump spring
did a wuick search and saw someone used a trimmed ss washer another said that it had to have room to have oil flow around it...??? they said use a ball bearing?
what did yall guys use and how thick was it? i just want a little more pressure...
Old Jul 14, 2008 | 07:10 PM
JPH's Avatar
JPH
I think SLP sells the shim if you want to just buy it?
Old Jul 15, 2008 | 09:25 AM
Michael V's Avatar
Guys use a nut laying flat between the end of the spring and the plug. Most use .100", also make sure to use a little sealant on the plug.
Mike V
