need some feedback on the comp r lifters
Old Jul 14, 2008 | 04:42 PM
matman11's Avatar
Default need some feedback on the comp r lifters
i'm looking to purchase a set of lifters for my forged 347 w/ a trex cam... wondering how the comp r lifters r and if anyone has had any problems w/ them.. thanks
Old Jul 14, 2008 | 04:52 PM
vettenuts's Avatar
A lot of guys have had problems. Read the Comp literature, recommended preload is 0.002-0.004" requiring an adjustable valve train. Morel is a much better lifter, have you looked into them? They will sustain heavy spring loads and are made from much better materials. Crane also has a new lifter out that is a step above. Both of these lifters are used by the offshore racing guys, who beat the snot out of lifters compared to a car.
Old Jul 14, 2008 | 05:04 PM
brad8266's Avatar
Dont even bother with the comp r's. Go with Morels.
Old Jul 14, 2008 | 06:49 PM
matman11's Avatar
those cranes are almost half the price are the morels that much better? if i go w/ either or these 2 will i need to get self adjusting rockers? or can i get the non adjustable
Old Jul 14, 2008 | 07:05 PM
JPH's Avatar
JPH
put the cranes in it, you can still run the stock rockers. Let me know and I will give you the correct part number to use.
Old Jul 14, 2008 | 09:00 PM
brad8266's Avatar
There is no such thing as a self adjutsing rocker arm.
Old Jul 14, 2008 | 09:25 PM
Ryan02SS's Avatar
Honestly I would steer clear of Comp on about all things. They have really cut cost thus cutting quality in the past 2 years it seems. From their 918's to their Pro Mag rocker arms they are having problems. A few in the offshore powerboats have had their Comp rockers breaking at the needle bearing. Perfect valvetrain geometry was found. Swithcing to Crane Golds cured the problem. I have had 2 bad Comp hyd roller cams. I went with Morels on my marine SBC which is run twice as hard as a car. I originally went with Comp's but was swayed to Morels on good info from builders. Comparing the two side by side was a no brainer.
Old Jul 14, 2008 | 09:28 PM
OUTLAWZ RACING's Avatar
What about ls7 lifters? i wish the ls7 lifters where out when I bought my comp r I havent had any issue with them after 3 years and Im boosted with a big cam.
Old Jul 14, 2008 | 09:42 PM
litle88's Avatar
The Ls7 lifters are not the replacement lifters for the Ls1's. So thats a good thing I guess!
Old Jul 14, 2008 | 10:23 PM
I know two people that use the ls7 lifters one on a 418 vette and the other on a head and big cam ss vert. I mean dam for 150 bucks a lifter that can see 6k+ I wish I had them but they fit with no issues and my boy with the ss pounds that car any chance he gets.
Old Jul 15, 2008 | 06:07 PM
eallanboggs's Avatar
I installed Comp Rs in my GenIII nearly 10 years and 100K miles ago and it has never skipped a beat. Maybe their quality control has taken a dive recently, but I don't have personal knowledge of that. This engine also has a big Comp Cam, Comp 1.85 Pro Mag rockers and Comp Hi Tech pushrods. The whole top end on this LS is Comp(supposedly the "bad stuff" according to the above posts) except for the heads which were CNCed by Richard at WCCH. I expect this motor to run another 100K without a tear down. If you use Rs set them to zero lash and stop. No extra preload. I did have one 918 break years ago. The spring held together even though it was broken. I didn't even know the spring was broken until I pulled the heads apart to ship them to Richard at WCCH to have him do the mill work.
Old Jul 15, 2008 | 06:42 PM
JFM-jr's Avatar
I had a Comp R's retaining ring come out and apart. Found it on my drainplug and I have the Caddy lifters in there now. Time will tell. . . . . .
Old Jul 15, 2008 | 07:58 PM
JPH's Avatar
JPH
to much preload on that particular sytle lifter, thats why the retaining ring came out/apart. But, I still wouldn't use them at all.
Old Jul 15, 2008 | 08:24 PM
07gsxr750's Avatar
keep it simple, get some ls7 lifters and never look back
Old Jul 15, 2008 | 08:27 PM
I agree big time I need to put some in mine
