car hesitates off idle, ~3000 RPM
With the overlap of the cam and the attendant reversion pulses / low maf signal at low rpms coupled with the lack of an accelerator pump function in the tune, drivability tuning is critical as hell - a lot of work in the VE tables is necessary to get everything balanced along with proper timing. I'm running a Futral F14 (235deg / .600 lift / 112 ) and after getting the WOT settings done on the dyno, I've been gradually tweaking in the drivability part - so far, so good, but it's a lot of datalogging, etc as I'm still learning.
Hopefully, you can get everything tuned in.
Bird
Bird
i can be sure that the hesitation is not due to the spark. i have had ignition problems on a different car before and thats not the problem.
this is not my DD car, there is a reason i went huge cam and dumps and 315s out the back. i absolutely love it and wouldnt have it any other way. i wanted the cam to give me the fastest time possible, and with my future mods it will. i know you dont drive WOT all the time, but i dont understand the point of being the fastest part-throttle car. you can always give it more gas if youd like to go faster. sure, a car with more torque is more fun to drive, but when im getting on it im going to be in the upper rpm range anyway, if im not then ill downshift. its really not hard to drive in a cams range. i can understand my cam might be overkill for some people, but some people (ie, me) like it that way. why dont you think everybody is driving around with TR224s? they have different tastes.
i have pretty much determined its a tune related problem, thanks to all who have helped out.
Bird, what would you say about buying software and tuning LS1s yourself? i know tuning is very in depth and difficult, but if you could do it over again would you just pay somebody to do it or would you still DIY? its something ive been debating but ive tried tuning before and i just couldnt learn enough to make it worthwhile.
UNDER PRESSURE MOD
Well, I reccomend getting the tuning software and doing it yourself. That way, you can learn what the car is doing, and know exactly what was done to the car.
Invest in whatever brand of tuning software, I have HPtuners but plenty of people also like EFI live, and a wideband O2 sensor. This way, you'll be able to fully diagnose exactly what's going on with your car, and then make the correct adjustments.
Everytime I drive my car, I data log, just so I can have a point of reference of what's going on with it. If it feels a little sluggish, I can look at the logs and see why.
It's all a matter of personal taste and preference. I personally have this car as much as a hobby with working on it as it is a driving experience. So to me, any work that's done of the car I want to be a part of. not saying I can do everything myself, but if something is going to be done, I want to know exactly what's being done and be there as well.
Bird
