PatrickG please chime in on this. heads cam combo question
5.3 is a great budget head but for ported stockers the 243/799 head is the way to go
you say you're aware they flow better and that you know they will increase compression but ask if you will pick up any power, I guess I dont get it.
And as far as someone telling you which head will be better you would have to post all the specs etc... of each head, if you are asking if the ported smaller chamber 5.3's will give you more power than stock then I think you need your med's. Who's 5.3 stage 1.5's, what are your stock heads, how extensive on the porting of your stockers if you did port them etc etc etc.
Your question leaves too many questions to be asked. Or maybe I am just being detailed about answering your question, anyways...
if its cheap to get a set of worked over 5.3's then I think I would go that route.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Flow Data
LS1 5.7 Stage 1.5 ````LS1 5.3 Stage 1.5
Lift Intake Exhaust ````` Lift Intake Exhaust
0.1 66.8 52.1 ````````0.1 67 53.7
0.2 138.6 108.5 ```````0.2 140 122
0.3 200.4 160 ````````0.3 203.5 172
0.4 248.5 209.3 ````````0.4 250.6 218.2
0.5 283 236.9 `````````0.5 288.9 244.4
0.55 295 247.4 `````````0.55 302.9 254.7
0.6 300.4 255.3 ````````````0.6 313.7 260.5
CNC Port LS1 5.3 and 5.7 Head to Stage 1.5
3.900� Combustion Chamber
Competition Multi-Angle Valve Job
Blend Valve Job
Mill Heads to Customer Specs
Flow Intake and Exhaust Ports
Heads Cleaned, Set Spring Heights, Assemble, Seat Pressure, Installed Height, and Coil Bind
Ferrea 2.020 Intake Valve
Stock LS1 1.550 Exhaust Valve (REV 1.57� Exhaust Valves are also available)
Standard TEA .650" Lift Dual Spring� (Comp 1.250� 921 and Comp 1.440� 978 are also available)
TEA Titanium Retainer
TEA Locators
GM Locks
GM Intake and Exhaust Valve Seals
i guess that the graphs tell it all right there. the heads im looking at are milled .010
And yes as stated compression is your friend but it would be better to raise your compression by going to a 243 casting that has a quench pad that lowers the chamber volume and results in higher compression rather than cutting way down on the head, because like Patrick G stated, then you run into piston to valve clearence issues, and thats leaving out all the good things that quench pads do for high compression and detonation damnpening.
Im not even going to go into smaller chamber/vavle shrouding because I dont know what you plan to do or what is done to the chambers and I definately am no guru or genious in this matter.
Sorry I dont know much about all the different castings, but the 853's are stock poopy just like the 241's. I picked up a set of 243's with 30k miles for 200$ two days ago and will be using them.
A point gained in compression yields 4% increase in power ( believe it was 4 or 4-5 )
But if you can then also add a quench pad thats just that much more compression you can run safely without the worry of knock.
If any of that was incorrect feel free to correct me, im pretty tired and didnt proof read it very well. Please if any of that is mis info point it out.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
