$2000 to spend on engine.
Old Jul 25, 2008 | 04:03 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
There is an order of operations that needs to take place. With a cam you absolutely need a stall and headers, so a stall converter and headers need to before a cam. To run a cam, the supporting mods should be in place first or at the same time. Whether you get the cam right away or not, you should get a tune after the stall and headers.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jul 25, 2008 | 04:23 PM
crashinaz's Avatar
I might add that the cam should be picked prior to ordering the stall...
Old Jul 25, 2008 | 04:39 PM
bigfoot2thefloor's Avatar
save another 1000 and do it right!
Old Jul 25, 2008 | 07:49 PM
00_Z-28's Avatar
I would get headers first. If you wana make your money go as far as it can stay on top of the classifieds and some will pop up be4 to long. If you wana save even more money and don’t have emissions in your state don’t bother with a exhaust. Run some pipe back put on a glass pack and dump uhm. Then stall. I wouldn’t buy used on that one. Unless you really trust the seller and it will match your future cam. I always recommend EDGE. I run one and am very happy with it. There about $600. Then save whatever money you have left and get a good set of heads, ( or just have your stock ones worked on. Depending on which cam you go with), new springs, push rods, oil pump, intake depending on what year your car is , slicks and cam.
