Just stripped the threads on a rocker arm bolt...
oh and is Heli-coil self straight forward or is there some sort of write up etc to do this? sorry for the noob questions, but its been a long week and i thought i was gonna have this up and running tonight.
Try it first on something else, even a piece of wood if you have to just so you understand what needs to be done as you only get one shot at it, if you have questions post them up. Good luck, hope it comes out OK.
Here's a link:
http://www.mcmaster.com/
Type in Helicoil and click on "view catalog pages (5)"
Start on page 3200 and find the parts on page 3202.
I would also practice drilling, tapping and installing an insert or two on a scrap piece of aluminum. A bushing to guide the drill would be of a great help. If you know someone with a lathe, a piece of round steel about 1 inch in diameter and about 1-1/2 inch long with a hole thru it the size of the Helicoil tap drill will work. The end of the bushing needs to be square with the hole.
If in doubt about your abilities in this area, seek help from a machininst. If you mess up the Helicoil installation the repair will then becomes very costly and requires removing the head.
Don't overtorque those (or any) bolts. Read and obey the torque spec.
Good luck.
Jon
