224 cam in
Old Jul 30, 2008 | 09:58 PM
JimsWS6's Avatar
yes I changed the pushrods..... And I was thinking about 6300 for max power also. I ordered a wideband o2 last night. and a week from this saturday is test/tune at the local track. So I think i'm gona run her.
Thanks to everyone for your replys!
Old Jul 30, 2008 | 11:33 PM
SladeX's Avatar
My limiter is set to 6500, but due to my 112 LSA, it peaks at 5800. I figure if I ever do heads I'll get a small boost in peak HP to just a bit above 6000 but nothing drastic. I rarely see 6500 unless I feel like it.
Old Jul 31, 2008 | 02:18 AM
twitchtwice's Avatar
+1 with what everyone says, once you get it tuned and running right, you will notice the difference.
Old Jul 31, 2008 | 04:59 PM
zman1969's Avatar
Default Under the curve
Originally Posted by 8secbusa
Flat TQ curves.. To add to the deceptive nature of a flat Tq curve is. My small block nova made 426 hp at the wheels with a 4800 stall... My buddies small block with vortec made 610 (manual trans). To ride in both cars, you would swear his car was a full second faster. Not because on the gear ratio, becuase when he hit 6000rpm, it pulled like an SOB.In my car, you never felt a dramatic burst. I ran 10.2's at 128 he has stayed in the 10.6 range at 130. We both dynoed at the same shop, his graph looked like mount everest, mine was a steady increase, void of any dramatic pronouned peak. The dyno operator told us at the time that my car would et better, his would mph the same if not better. His rationale.. my average HP & tq was greater.
well put - yet so few understand this - its Torque that accelerates a vehicle
Old Aug 6, 2008 | 03:39 AM
beezer1519's Avatar
well that's funny because i just installed my cam it's a 221/224 on a 112 and i felt a big difference from that and the underdrive pulley and that's without getting a tune my question is could it be bad to run my car ***** to the wall without a tune? reason being is races this friday and i wanted to put on my pacesetters before i got a tune.
Old Aug 6, 2008 | 09:15 AM
01ssreda4's Avatar
well i had a full hptuners done on my car when i recently put my stall converter on and it was running great. i just put a tr224 cam in and was expecting all kinds of chaos. but none. it drives great except it cant idle well bc of the idle speed being set too low. i went WOT and it feels great. i dunno if i would take it to the track but then again im fairly cautious.
Old Aug 6, 2008 | 09:23 AM
PREDATOR-Z's Avatar
Well I spent 15 hours this weekend swapin my cam. Wasn't a bad job. the springs were a pain in the back cylinders. But otherwise went pretty well. Car started right up, instant oil pressure, everything was fine. (knock on wood)
I broke it in as instructed, sounds amazing. Just what I was looking for. You can barely tell it's in there, by the exhaust note. But still idles pretty smooth.
I know with the 116 LSA I wanted , it'd move the powrband up. But tonight was the first time I hammered on her and honestly It wasn't what I thought it would have been. Before she pulled hard all the way. It feels like a picked up a few ponies. Not what I thought. Have yet to up the rev limiter, she stopped at 6k or so.
And yes I did get the timing marks 100% dead on. I checked about 5 times after installing the chain. Turned the motor over by hand a few times. It drives great, can't tell the cams in there. Just not to impressed by the gain I'm feeling.
We have Hptuners, and I still have to buy a wideband to tune it with. But even without a tune shoudln't it feel like more of a gain? I think my UD pully I put on a few months ago felt better.
What do you expect if not tuned properly?
You know the answer, professionaly tune it, then dyno fine tune and then make a judgement.
This is like arguing why is the chicken not black while the egg hasn't been fertilized yet.
Old Aug 6, 2008 | 03:26 PM
beezer1519's Avatar
don't get me wrong i'm trying to find out if it'll mess up my car without a tune before i go to the track if it's highly not recommended then i'm going to have to skip on the track this time.
i'm fairly cautious also but if race gas will keep the main problem down (running too lean) then i'll go have fun and have it tuned... anybody have any comments...
how long did some of you run your car with a cam before you had it tuned?
Old Aug 6, 2008 | 05:37 PM
BIG_MIKE2005's Avatar
I have been daily driving mine for a full year on 87 octane witrhout a single issue & it's untuned. Had several races too & still no issue. Only a little unspent fuel blowing out from running rich.
Old Aug 6, 2008 | 09:19 PM
Striker's Avatar
I also dislike super choppy idles....after reading this thread, im just wondering whats so bad about a higher LSA, just that it moves the power band up, but it does get the car to idle nice and smooth, close to stock, correct?
**What power numbers can you see with a TR224 114LSA with a good set of heads. Sorry i dont mean to hijack the thread.
Old Aug 6, 2008 | 10:04 PM
Breathtaker's Avatar
A couple of weeks ago I bought the TR224/224 114LSA and won't install until I get the heads too.
Old Aug 6, 2008 | 11:01 PM
  #32
01ssreda4's Avatar
my tr224 114 idles pretty smooth. if the idle speed was picked up it would really smooth out. i bet to an untrained ear it would pass for stock.
