Cam replacement, what else should I look at
TIA
Ported Oil Pump
Pulley
New Valve Springs
Ti Retainers are a good idea
New Pushrods
I also bought Yella Terra 1.7 Roller Rockers, more for preventive maintenance against rocker arm failure than anything else
I am planning to install the ASA cam and LS6 springs in about 6 weeks. I think I will go with a new oil pump, timing chain, new pushrods, and ASP pulley while I have it all apart for sure. I am not so sure about new retainers and rockers at this point? Do I need to check the rod bolts or anything in the bottom end while I have it all apart?
TIA
David M
I wouldn't worry to much around rebuilding, take care of it run it until blows up then get a replacement. Rebuilding it right will cost about as much as replacement.
