Cam which one to buy
Old Aug 5, 2008 | 09:56 AM
JS01SS's Avatar
Smile Cam which one to buy
Hi, I have a 2001 camaro ss. I am going to redbuild the motor. I was wondering how many people are running the texas speed cam 224,224 with the 566 lift and 112 lsa. Also the thunder racing cam 224,224 with 563 lift and 112 lsa. What do you think of the cams. Are there better cams out there. The car will be a d/d. But i want it to sound like it has a cam in it. I also have a set of 243 heads off of a 05 gto and header to go on it. Thanks JS01SS
Old Aug 5, 2008 | 10:02 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We've done tons of dyno testing with 224ish duration camshafts. The 224R camshaft is more driveable & makes power earlier than the 224 with xe 566 lift. I've personally dyno tested them next to each other & next to the 228R camshaft. I personally prefer the 228R because it gave up almost nothing down low & made 8rwhp over the 224R camshaft. The owner of the car couldn't tell any difference in driveabilty, but he still gained some hp!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Aug 5, 2008 | 10:07 AM
SOMbitch's Avatar
It depends what you want out of the car. I personally went a little bigger. I would go 224R with 588 lift and XE-R lobes though if you decide on a 224. The 228 with a good tune is a nice DD cam too.
EDIT. Damn Jason, beat me to the punch lol
Old Aug 5, 2008 | 10:12 AM
Redlinez's Avatar
AFR #6016 224/228 581/581 114 is a great all around one as well.
Old Aug 5, 2008 | 10:23 AM
180ls1's Avatar
228r is the way to go.
Old Aug 5, 2008 | 02:09 PM
snake charmer's Avatar
i am running a 224 228 on a 114 with .588 lift . you can click on the link in my sig to see what else and the base dyno .
all around car drives much better after it got tuned . great combo and still some power out there .
Old Aug 5, 2008 | 02:11 PM
smokeum99ta's Avatar
Here you go https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html found it in the STICKY!!!!!!
Old Aug 5, 2008 | 04:07 PM
ZMONSTER!'s Avatar
numbers heads and cam in sig. Drives great and feels like stock till you get on it!
