What causes this damage to a cam?
Old Aug 10, 2008 | 01:39 PM
fasttimes1's Avatar
Default What causes this damage to a cam?
I just pulled this cam out of my car because Im going with a different setup. I noticed some rough spots on two of the lobes. I dont really know what causes this (bad lifter?), or if the cam is usable anymore. I had intentions of selling it, but dont want to screw anyone.
Pics:
Old Aug 10, 2008 | 01:52 PM
Randy WS6's Avatar
The cam is definitely wiped out, It looks like the roller on the lifter locked up and was dragging on the lobe
Old Aug 10, 2008 | 02:32 PM
Michael V's Avatar
If you have a magnetic drain plug, you should have picked up increased debris with this damage. Its important to monitor this debris.
Mike V
Old Aug 10, 2008 | 02:33 PM
PREDATOR-Z's Avatar
Either that or tha cam wasn't hardened enough, but yeah, that cam is toast. Now you have to pull the heads, time to change the lifters.
Old Aug 10, 2008 | 04:29 PM
davered00ss's Avatar
Moderator
Comp has issues with their cams a year or two back doing something similar.
Could be a number of different things. I would change the liters.
Old Aug 10, 2008 | 05:06 PM
fasttimes1's Avatar
Im replacing the lifters either way, but I found very minor abnormal wear marks on only 1 lifter, and the rollers on all of them seem fine (may not be fine at engine rpm though). Heads are removed already, they are at the shop being cleaned and inspected. New lifters were in the plans already, custom grind cam will probably be ordered this week.
Thanks for the replies.
Old Aug 10, 2008 | 05:10 PM
vettenuts's Avatar
Likely causes:
1. Insufficient valve spring seat force and stiffness to keep up with cam
2. Pushrod flex
Less likely but could also be:
3. Improper heat treatment of cam
4. Improper heat treatment of lifter roller
5. Inadequate lifter roller material properties (less expensive steel)
If only two lobes, check the valve springs. Also, lifters likely need replacement as well.
Old Aug 10, 2008 | 11:08 PM
Full-Force's Avatar
That wouldn't happen to be a Futral cam would it? Seems like a year or two ago alot of them were doing that. Cam Motion was the supplier.
Old Aug 11, 2008 | 10:38 AM
fasttimes1's Avatar
Full-Force: Its not a futral cam.
vettenuts: Im running GTP Stage 2 heads which come with springs that should be able to support the lift on this cam. Along with that I have comp chrome moly push rods, but have stock lifters. Most of my valvetrain is being replaced either way: cam, springs, pushrods, lifters, & timing chain. Thanks.
Old Aug 11, 2008 | 11:12 AM
vettenuts's Avatar
I would also consider stiffer pushrods, 5/16" pushrods are pretty flexible with the springs/cam lobes typically run in an LS1.
Old Aug 11, 2008 | 11:43 AM
69LT1Bird's Avatar
Perhaps the lifter rotated due to a worn lifter holder, and ran sideways on the cam briefly.
Old Aug 11, 2008 | 12:06 PM
ThirdGenLS1's Avatar
yea i would replace the lifters, cam, and run either a 11/32 or 3/8 inch pushrod
Old Aug 11, 2008 | 01:06 PM
fasttimes1's Avatar
Definitely going with a stiffer pushrod. Never thought about the lifter holders, Ill take a look at them.
Old Aug 11, 2008 | 04:41 PM
vettenuts's Avatar
Check for one stamped "10" on the bottom, some of those have been documented as having a slight angle to the lifter and under higher spring forces wearing the roller off of the lifter.
Old Aug 11, 2008 | 09:12 PM
02 BLK WS6's Avatar
That cam will make a good paperweight.
Old Aug 11, 2008 | 09:19 PM
fasttimes1's Avatar
Those paperweights add up after several years...lol!
Old Aug 11, 2008 | 11:21 PM
mvvette97's Avatar
what kind of cam is that?
Old Aug 12, 2008 | 08:27 AM
fasttimes1's Avatar
Its a Comp Cam.
Old Aug 12, 2008 | 11:57 AM
mvvette97's Avatar
I thought I was safe buying a comp but after this I may not be after all.
Old Aug 12, 2008 | 01:40 PM
fasttimes1's Avatar
Dont think its a cam issue though, just havent inspected deep enough to find the cause yet.
