Cam bearings
Old Aug 11, 2008 | 10:47 AM
veloxetmortifer's Avatar
Default Cam bearings
Does anyone have a link for a walkthrough on how to remove and install new cam bearing. I just got a 224 cam and I was told that it was going to be a good idea to change the bearings. Any info would help. Thank you.
Old Aug 11, 2008 | 11:47 AM
87silverbullet's Avatar
How many miles on your motor? I wouldn't change them if you have 60 thousand miles or under. Hell, I've done h/c/i swaps with 120,000 mile cars and didn't have any problems.
Old Aug 11, 2008 | 12:07 PM
ShevrolayZ28's Avatar
Cam bearing replacement is probably not a do-it-youself type of job for the average guy. And like 87SB mentioned, it's unlikely that they need replacement. Many people install cams without new bearings...
Old Aug 11, 2008 | 02:28 PM
john563's Avatar
My first cam whent in at over 60k,and no cam bearings were replaced and my second cam whent in at 75k and left cam bearings alone
Old Aug 11, 2008 | 02:40 PM
Randy WS6's Avatar
Plus the motor hast to be out of the car to remove and install the new cam bearings.
Old Aug 11, 2008 | 09:34 PM
I have 75K miles. Thanks a lot for all the info.
Old Aug 11, 2008 | 09:43 PM
ss69's Avatar
x2 on this
Old Aug 11, 2008 | 10:15 PM
01ssreda4's Avatar
100k here. stock cam looked beautiful and my tr224 went in and spun perfect.
Old Aug 11, 2008 | 11:34 PM
Jeff@TotalPerformanceEng's Avatar
High mileage cam bearings are fine provided their not tore up. If you've got the cam out, take a small extendable mirror and look at them. Dont be concerned if you see copper. Its not uncommon.
If your oil pressure was fine before, your fine..
Replacing cam bearings is a BITCH, and can only be dont properly with the motor out, and upside down on a stand with all the covers off. Even then, its a bitch.
Dont do it unless you have to..
Old Aug 14, 2008 | 12:00 AM
Muchas gracias. Thanks again for all the info. I really appreciate it.
Old Aug 14, 2008 | 11:33 AM
CriminiSS's Avatar
2nd that its a bitch with the rotating assembly still in place. If you not absolutely sure u have to replace them then don't.
