Eagle rod install stupid Question
Old Aug 29, 2003 | 11:57 PM
blu00rdstr's Avatar
Default Eagle rod install stupid Question
OK, I have a stupid question.
What side of the rod goes against the crank arm, and what side goes against the neighbor rod?
One side of the big end has an inside chamfer, the other side is flat. Both flat and chamfered sides have a rough finish, the stock rods had a flat machined surface on both sides.
Old Aug 30, 2003 | 12:12 AM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Eagle rod install stupid Question
The flat parts face each other and the chamfers face out (towards the crank).
Rod Journal |(chamfer)(flat)(flat)(chamfer) | Rod Journal
Old Aug 30, 2003 | 12:49 AM
blu00rdstr's Avatar
Thanks! That's the way I have it, but just as I was installing I thought that was wrong.
It seems weird to have the chamfered side to the crank, when there's not always crank next to the rod. The crank arm tapers to the wrist pin and leaves no material to support the side of the big end.
Old Aug 30, 2003 | 05:04 AM
Reckless's Avatar
Super Moderator
Make sure you pay attention to the rod bearings also. There is an upper and a lower, and they have a slight chamfer as well that matches the machining on the rods.
Old Aug 30, 2003 | 08:57 AM
Country Boy's Avatar
Senior Member
Hey Jason, got pics of that?? I know the stock LS1 rods all face the same direction in the block.
Old Aug 30, 2003 | 09:07 AM
LS1derfull's Avatar
common sense will answer most questions you may have.Chamfers on bearings and rod big ends are there to insure clearance for crank journal radius.Makes sense, there's your answer.Be sure to check rod side clearance with each pair torqued in place. It helps to torque rod bolts with feeler gauge between caps to help set caps alignment while torquing. A good rule of thumb would be .020" min. clearance.
Old Aug 30, 2003 | 11:41 AM
Jason99T/A's Avatar
Carl, yes, the stock LS1 rods all face in the same direction.
I'll see if I have any pics when I get home of my forged 346ci buildup and the last one I did with stock pistons/rods.
Jason
Old Aug 30, 2003 | 11:54 AM
Senior Member
Damn... Now I think I know why my oil pressure sucks and acts like a loose bearing I put the Eagle rods in with the same orientation (sp?) as the stock rods. The stock rods have the offsets facing in one direction, so I did the same for the Eagles
Old Aug 30, 2003 | 12:58 PM
blu00rdstr's Avatar
Sh*t. Good thing I'm not using TTY bolts.
Old Aug 31, 2003 | 12:25 AM
blu00rdstr's Avatar
Checked the bearings, Clevite standard don't have a chamfer.
