TSP Goes Back to Engine Dyno with Stock 346 LS1!
Jon,
I run a TR224-112 and I do really like it but I see alot of people that live at higher elevations (4500"+) asking for help on "best thin air" cams.
Is there a possibility you could look into something that would help us? I know we are probably not the majority of your market but we are cuter up here.
i would like to see back to back comparisons between 2 midrange cams using different lobes, nothing else. 230/236 on xer then on xfi or something. same icl and advance.
i'd also like to see a high duration on narrow lobe separation, ie 244 on a 108 or whatever you can get to fit...but using a vic jr instead of these gay crossover style intakes.
What about Head to Head BIG CAMS..
The Vindicator vs The MS4 vs the Polluter..
I think that should be an awesome comparison since all three cams are very popular here on Ls1 Tech
Why not to slap some TFS on there too???
#32
+1 on the small cams, I have a 218/224 in a 6.0L truck. I would like to see something that provides flat off idle torque up to 4500 RPm's or so, then HP shouldn't exceed 6K RPM's. I'd like to see a 214/218 or 210/216 - something in that area.
#33
id like to see a low 240s cam with mid 600 lift
#34
I'd like to se my cam versus the same .050" duration LSK or XFI lobes. I have a Comp XE 226° .571"/ 230° .575" on a 109° LSA +0°. I'd like to see the difference in touque and power compared to the faster higher lift lobes.
And yes, that slow ramp with the longer duration at .006" combined with the 109° LSA means the idle sounds like a Harley Davidson.
#36
Hold Alt+1+6+7 and release at same time.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
#37
heads...
Id like to see some decent sized cams put with tfs, aft, and any other heads you can get your hands on and see how they differ.... It would be nice to see what makes more power... My money is on tfs....lol
#38
Heads comparasion
http://www.gmhightechperformance.com...ads/index.html
#39
are you looking for cams to be donated, or are you looking for some specs to be tried out... If you are buying the cams, I have some specs I'd like to see tried out...
BTW, for folks who want to see a bunch of small cams that were already tested I need to find the data from Sam's Performance in Australia. They tested tons of cams and headers. I have to look for the article and the dyno sheet, but there were a ton of them tested.
#40
Texas Speed:
Any chance you guys sell stock in your company?
Judging by the response, many people are hungry for any new jump in cam performance and technology.
Need a donor car?
All joking aside, I think you have everyone's interest. I like many others will be eagerly anticipating the results.
Good luck!
..WeathermanShawn..
Need a donor car?
Good luck!
..WeathermanShawn..
