motor ticking bad!
I would check this first. It sounds stupid but I pulled all my passenger side rockers and pushrods to later find a loose plug.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Restricted User
Just fixed mine. Ended up being the rockers. Here's the thread:
https://ls1tech.com/forums/generation-iii-internal-engine/975450-fixed-ticking-squeeking-coming-my-valve-train.html
well I pulled the valve covers and the rockers look fine, one of the push rods may be bent, so tomarrow I'm pulling off the rockers and push rods to get a closer look
Yeah, Ive been where you are. My buddies car had a ticking noise and was setting a P0300 misfire code from # 7 cylinder. We first checked the pushrods and they were not bent, so then I did a compression check on #1 and #7 for a comparison, and #7 was about 65 lbs lower than #1, so that told me we either had a bent valve or hole in the piston. So we pulled the head off and sure enough we had a chunk of the piston gone about the size of quarter.
Hi
Here is my engine before i replaced the lifters on the passengerside.
http://s175.photobucket.com/albums/w...0080718006.flv
And here is what it sounds like after.
http://s175.photobucket.com/albums/w...0080822014.flv
Its still some noise from the fuelrails.
Hi
#35
This is weird. The sound went away. I retuned my idle and took my timing down more on my map and smoothed them more. I also lowered the idle speed to 825 cause before it was set at like 950. It idles good and runs like god, you dont think it was the timing do you? Well either way it is gone for freee! I know this is not my thread but thanks for the help.
#37
well i found a slightly bent push rod, so i bought chromoly ones, and got some rockers that only had 33k miles on em, put it all back together, and no difference, still ticks, so its either a lifter, or bottom end, I'm leaning more towards lifters as I've read, I was just hoping to not have to do that
