LQ9 Questions... Cams heads and stuff
1.) What Cam would be better? Stock LQ9 or my GM Hot Cam and LS6 Springs?
2.) Would LS6 heads fit/work fine just bolted on like the way they are?
3.) What mods would need to be done or would it just drop into my car?
The reason I ask is because my motor is blown and well 6.0 wouldn't be a bad route. Please help ASAP before someone buys the motor... Thanks
PS. Probablly won't be spraying for a long while
the 317 heads are ls6 heads with bigger chamber, mill them .020 if u do remove them,
the hot cam will be better than the stock cam
no ls1 fbody heads are better than 317 heads
are u sure its a lq9? a lq9 and lq4 look identical with the heads on.
lq9 has flat top piston, lq4 has dish
like i said, do not remove the heads, the 317 are ls6 heads.
just install your hot cam, springs and go
the 10:1 compresion is good enuff as is for the hot cam.
if anything, add ls6 rod bolts or arp rod bolts and ported oil pump
