good amount to mill 5.3L heads, what compression
Old Sep 3, 2003 | 12:43 PM
Fireball's Avatar
Default Re: good amount to mill 5.3L heads, what compression
My 5.3 heads were milled .40 and I was told I had a 57cc chamber
Jeeeze ... That thing must have the CR of a diesel!
I can't see how it runs on pump gas unless it's loosing all it's timing due to knock retard.
same with my engine.... 0.040 off 5.3 L heads. I was told its ~11.8:1 Runs just fine on 93 octane (for the last 1.25 years)
Old Sep 3, 2003 | 01:24 PM
Mustang Hat'r 2's Avatar
I had .015 milled off mine and have 11.1 to 1 C/R and run the stock length pushrod(7.4) The TR cams base circle is .03 smaller than stock so there is no problem with milling the .015.
Old Sep 3, 2003 | 01:54 PM
ONEBADWS6's Avatar
Ran fin on pump gas with 28* of timing. No knock with a 13.3AFR. Why would that be to much compression for spray?
Old Sep 3, 2003 | 02:28 PM
Tally TransAm's Avatar
dont you want a lower compression for a nitrous shot, or is that just blown applications, i might have had a brain fart
either way i just ordered my heads, 5.3L milled .015 for 11:1 compression and running 7.4" pushrods
cant wait to get them
