LS1 Camshaft Engine Dyno Comparision
DoD and VVT engines are what these pumps come stock on.
I made pretty good power with my MS3, waiting on replacement heads(just ordered today), I'll post up my power difference once installed. 05 version stage1 ls6 heads made 460 rwhp with I think 409 rwtq. Hoping the newer stage 2.5, 5.3's improve on those numbers.
And also as a question, for the MS4, Whats the standard piston to valve clearence with 241 heads? One thing that kept me from looking at it was its huge intake lift and the worry that running a .030 cometic gasket wouldnt be possible.
i highly doubt the Comp 224/224 .581/.581 112lsa im running that i installed 2 years ago has either lobe design. how would i even begin to know? showed nothing in the cam package in regards to that...
benefits and contraints to each lobe design? thanks.
the "Cam Guide" doesnt break out the different lobe design or characteristics...
so are we talking about faster ramping rates, quicker revving cam(s) so to speak? do the assist in benefitting lower RPM power (not power under the curve), meaning where the cam flows around .200-.300 lift, etc.?
(I wonder if that means you could use a PAC 1218 spring with them
)Though TSP are saying they didn't see the gains expected from this new XFI fad.
Awesome info! But between the TQ3 and the tsunami, the TQ3 has better power up to 5900 RPMs against the Tsunami. And im just curious, but did the tsunami spike @ 6600rpm's?
The MS4, Tsunami, & the TQ3 produced very good power, but they are all reverse lift cams. What would be the difference if you put the MS3 cam in there, which doesnt have a reverse lift? Would it be possible to put the MS3 cam in on that same dyno and post some numbers so that we can compare them?
....what about the dyno results on the Texas-Giant!?
Thanks again!
PM ME IF YOU DON'T WANNA POST UP. I think I deserve it after all the money I spend, and continue to spend
, with TSP
Whatever lobes used and mixing of lobes ae not "fad". TSP knows that (LSK/XE-R) cams, so I doubt that any of their cam tech would make a remark like that.
Mixing lobes creates characteristics that a single lobe pattern might not be able to achieve.
Such as a 224/224 that is a no split cam if XE-R/XE-R,
While if XFI/XE-R it is a reverse at .200 and increases trq output in early midrange.
Vengeance knows that as well and is producing good results with XE-R/XE (high lift) mix.
So anyone just looking at .050 cam specs and making a judgement on a cam, is actualy looking at 1/10th of the whole spectrum, basicaly that person is legaly blind
Is it as easy as picking the most aggressive lobe around at any given duration and crossing your fingers that it makes good power? No.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
