Best cam for daily driven a4?
Old 09-15-2008, 05:39 PM
z28poweredlt1's Avatar
I'm not sure but an MS3 might be a little much without gears and a big stall?
I run it fine in an M6, but it would love my car a lot more if I had 4.10's. It doesn't like to be lugged at all... Well at least I don't like lugging it.
Old 09-15-2008, 05:42 PM
Pipelayaz's Avatar
Originally Posted by mike13
MS3 what brand of cam is that? can you run it with stock valve springs? Or should you upgrade?
The stock springs should ALWAYS be upgraded when you do a cam swap. The stock springs will hold next to nothing but a stock cam.
Old 09-15-2008, 06:15 PM
Z28SteveA4's Avatar
Not to be a pain in the butt but can you guys show us some times you are running with these cams?? I would like to be a mid 11's car with a smaller cam and minor head work done. I just want to see if its possoble
Old 09-15-2008, 08:00 PM
navyblueSS's Avatar
TSP 228R here. Very streetable and runs consistent 11.70s cam only with Yank 3600 stall, and the stock 3.23 gears.
Old 09-15-2008, 08:39 PM
mike13's Avatar
navybluess that's a pretty big cam, stock heads? Does it have a pretty healthy crackling idle? Also what rpm is your idle set at?
Old 09-15-2008, 10:36 PM
96gt4.6's Avatar
I chose the TSP 224R. My setup is in my sig. Won't know till Friday how much it picked up. Here's a vid of the cam installed and running. My cutout lid is off in the vid. It's towards the end of the thread on pg2.
https://ls1tech.com/forums/showthrea...=976342&page=2
Old 09-15-2008, 11:44 PM
Detoxx03's Avatar
Im running the F-11 from Futral and it is excellent
Old 09-16-2008, 06:27 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I went 7.4xs in the 1/8th with the F13, TCI 3K stall and 2.73s in my old Z28
Old 09-16-2008, 07:23 AM
ramairracer's Avatar
i daily a g5x2 230/240 with a yank pt4400 gets about 15 mpg with 3.73 gears...
Old 09-16-2008, 08:49 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Checkout our recent camshaft dyno post with engine dyno specs from several of our most popular camshafts. The 228R TSP camshaft made 75 horsepower gains!!! For the power & driveability this camshaft is really hard to beat. Huge horsepower & awesome driveability is pretty hard to beat
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
https://ls1tech.com/forums/generation-iii-internal-engine/982895-ls1-camshaft-engine-dyno-comparision.html
__________________
Jason
2005 Twin Turbo C6
Old 09-16-2008, 04:16 PM
  #32
navyblueSS's Avatar
The car idles at 900rpm, and has lopey, healthy sounding idle.
Old 09-16-2008, 05:43 PM
  #33
Blk_Ws6's Avatar
Originally Posted by 12secSS
I currently have an F13 as well, with a 3000 stall, but 3.73 gears. I daily drive mine, but each person has there own thoughts on what is acceptable. What are you looking to get out of a cam install? Is you car a street only or street/strip (not necessarily drag racing)?
Hey bro thats a pretty a@# picture of the ss.
Old 09-16-2008, 07:09 PM
  #34
95_ls's Avatar
+1 i'll be running a very similar set up and ived heard great things about the TSP 224 cam
Old 09-16-2008, 09:53 PM
  #35
mike13's Avatar
what kind of idle does the 224 cam have? Also how do you think a 224 or 228 will work with a 2400-2600 stall convertor?
Old 09-16-2008, 10:21 PM
  #36
96gt4.6's Avatar
Mike, check the link posted in my 1st reply or the post above yours. I have a VIDEO of the cam installed and ideling.
or....
here it is again.
http://www.youtube.com/watch?v=M2h64mlDi5g
This is the 112 LSA. Stock exhaust with gutted cats, cutout lid was open in the video.
Old 09-16-2008, 11:15 PM
  #37
Stroker396@APF's Avatar
I am DD a 233/236 w/114+4 in am M6 which I am sure does not help you at all.
But I am running a custom cam sale, you might want to take a look at. If you compare the lobes they are very similar to the comp XE-R
https://ls1tech.com/forums/sponsor-sales-specials/983282-brand-new-custom-cam-sale-355-shipped.html
Old 09-17-2008, 07:07 PM
  #38
SOMbitch's Avatar
With a stall that size I would go smaller with a 224. 224 on 112 LSA has plenty of lope
Quick Reply: Best cam for daily driven a4?
