Emissions Friendly Cam: TS 224R vs TS 228R
I know the TS 224R (.581/.581 114 LS) is capable of passing emissions. I'm wondering if going for TS 228R (.588/.588 114 LS) will pass or fail emissions. I'm also getting PRC 5.3 stage 2.5 heads with either cam. So which of the two should I get to pass Canadian emissions and get excellent driveability out of it, cause my car is a daily driver.
I am not sure about Canadian emissions, but the 228 on a 114 can pass California emissions with a great tune and cats. It is all in the overlap, you want zero or less overlap.
At 40 km/h
HydroCarbons parts per million - 18 (max allowable 58)
CO % - 0.01 (0.32 allowable)
NO ppm - 77 (435 allowable)
At Curb Idle
HC ppm - 33 (max allowable 150)
CO % - 0.02 (0.7 allowable)
LS1Tech Premium Sponsor
https://ls1tech.com/forums/generation-iii-internal-engine/982895-ls1-camshaft-engine-dyno-comparision.html
Checkout the cam dyno thead, we have the TSP 224 dyno tested next to the TSP 228 camshaft!!
70-75hp gains from a small camshaft swap!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
