V/P clearance
HEY PEOPLE NEW TO THE SITE. I bought a Lunati Camshaft. The Specs are
Advertised Duration (Int/Exh): 300/300
Duration @ .050 (Int/Exh): 242/242
Gross Valve Lift (Int/Exh): .595/.595
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 3500-6500
Part Number: 55009LUN
I Also bought LS1 heads ported and polished. these specs are:
2.02 intake and 1.60 EXHAUST
LS1 STAGE 3 PORTED HEADS
HEADS ARE PORTED. AND FLOWED @ 28" H2O
241 CASTINGS & 225 CC INTAKE PORTS
flowed on a Super Flow 600 Bench no pipe on a 202 valve.
Will i have piston to valve clearance?
LSA/ICL: 112/108
LSA/ICL: 112/108
LSA/ICL: 112/108
There's a lot that goes into calculating the piston to valve correctly. That being said my initial gut is it's going to be way to close. We've tested that lobe about 4 years ago and I doubt it will clear in this application without doing a little cutting
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
