Build up, what should I do?
Old Sep 16, 2008 | 05:19 PM
blk99camaro's Avatar
Default Build up, what should I do?
Well today I got off early and started to tear down the camaro for the cam and stuff..... got the water pump off, and then the valve covers and found this.........
There is a **** LOAD of old gunky oil build-up like this as you can see.....
So now I am at a point of weather or not just to take the motor out and freshen it up or what....any suggestions.....
I have to take the heads off and clean them up at the minimum.....hopefully i will get to take the k-member out tomorrow and check the bottom-end.....
For those of you that know me know how meticulous I am about my car....oil is changed ALWAYS ahead of schedule...usually at 2000mi.....I guess the previous owner didnt take care of the engine as well as the rest of the car.....
Old Sep 16, 2008 | 05:25 PM
philsblwnz28's Avatar
do a 6.0 with ls6 heads and cam
Old Sep 16, 2008 | 05:26 PM
BlackTTC6's Avatar
That'll teach ya for using M1..
I'd be interested on what the pan looks like.
Old Sep 16, 2008 | 05:28 PM
mike#9's Avatar
Where does it say that Mobil 1 was used?
Old Sep 16, 2008 | 05:37 PM
M1 has been used in it once in the last 20k(thats what the dealer put in it right before I bought the car), its always been syntec. This does explain why my oil looks like absolute **** after a few hundered miles.....
Old Sep 16, 2008 | 06:51 PM
SOMbitch's Avatar
My old 89 chevy 4x4 was worse than that Even the springs were caked and the only reason I found it was cause it would smoke at idle on a hill. You couldn't even tell springs were springs Guess drainbacks were closed in the back of the heads causing oil to get past the seals?? Scraped it all out while using a shop-vac and ran a wire down drainbacks and truck ran perfect for 45k + (217k) until somebody pulled out in front of me and totaled it. Depends on what you wanna do?? Might wanna try it?
Old Sep 16, 2008 | 08:35 PM
fatdave's Avatar
I would certainly take the motor out of the car. Can easily be done either from top or bottom. Before I put any new parts on it I would clean it all out and find somewhere to get the motor hot tanked. Then scrub it all over with some hot soapy water and a engine brush set to clean all of the journals and passages again before putting it back in the car. Would also invest in a oil filter cutter. Do a few oil changes a few hundred miles apart once its running again and cut the filters to see whats going on in there.
Old Sep 16, 2008 | 10:05 PM
99blancoSS's Avatar
If your going through the trouble of pulling the engine you might as well stroke it. I can set you up with a new rotating assembly w/bearings and you can have a local shop handle the build or I can do the whole thing for you. I just saved someone over 300 on a rotating assembly and head package so I know I can help you out as well.
Old Sep 16, 2008 | 10:09 PM
t/a98's Avatar
mine was straight black, i put my finger in it and it went atleast an inch deep, the people who supposedly took such great care of the car, obviously didnt, sucks huh?
Old Sep 16, 2008 | 10:18 PM
BerryWS6's Avatar
I would think that pensoil was used.
I would take the motor out
Old Sep 17, 2008 | 05:42 AM
The motor is coming out for sure, and right now it looks as if my build is going to start sooner than expected....but we will see how the rest of it looks(cyl walls etc)....
