Victor Jr Bolts And Gaskets???
Old Sep 22, 2008 | 02:35 PM
Sammyboy's Avatar
Default Victor Jr Bolts And Gaskets???
What size bolts does the victor jr intake use (If they are factory, I still need to know the size) and also, what type of gaskets, are they factory o-rings or thicker?????
Old Sep 22, 2008 | 09:04 PM
Shawn MacAnanny's Avatar
I'm not sure i have an extra set of them though (the bolts). The o-rings are just stock LS1 gaskets.
Old Sep 22, 2008 | 09:42 PM
TJ's Avatar
TJ
6MM in thread. im not sure on the length.
the intake purchased new comes with bolts, but it doesnt come with gaskets.
get the felpros from the parts house.
whole set cheaper than one GM gasket....
good luck.
Old Sep 23, 2008 | 07:11 AM
Sammyboy's Avatar
I just needed to know the thread and the length so that I could take some from work.
Old Sep 23, 2008 | 10:13 AM
svsgt1's Avatar
The correct bolt size for the Victor intake is M6x1.0 with a length of 50mm. If you are taking them from work, make sure to at least grab some stainless ones. lol By the way, you will need washers for them too if you don't have the bolts with the washer style head. (can't remember the name of that head style)
Old Jan 13, 2009 | 12:50 PM
383lt1impala's Avatar
Is the size above for a bolt or stud?
Old Jan 13, 2009 | 04:09 PM
A bolt a believe. I've never seen the studs.
Old Jan 14, 2009 | 10:13 AM
TJ's Avatar
TJ
its a bolt.
you could make your own studs, or try and find some that are about 60mm long.
that would do the trick.
