a builder says the tr224-114 is too big for stock???
There are also a group of people who have gotten rid of the 224 cam and wish they hadn't. It's human nature to think that the grass is always greener on the other side.
It's a great cam for the street; it makes great power with the right combo; it can pass a sniffer test, and it doesn't take a degree in rocket science to tune it.
I put a TR 224 114 in my 2000 ls1, with ls1 heads/manifold. I also added a ported tb at the time.
I got 44 rwhp from the cam/tb swap. Thats a ton, I think, for that top end! Its a great cam. And, it is most def not the same as a 224 XE-R for example, as posted, it has proprietary lobes.
FWIW, of all the dyno curves I've seen of ls motors (and I have hundreds on my pc to look at), the 224 has the best looking tq curve of all of them. Its almost perfectly balanced.
As many have stated, many including myself have 'moved on' to other cams (currently have a 253/259 112+4...but its in a 440!)...I'm a big fan of the TSP 231/237 for a 346 also, but its not quite as 'butter' as the 224.
I recommend either a 224 or 231/237 to my buds when we mod their 346's, and both are great.
I know the lobes are proprietary but what is different? more aggressive?
I had comp grind me a tr230 clone when TR told me it was out of stock and I could get the comp ground for $320 shipped at the time. I'm not sure which lobe profile was used as it's not on my card. lobe lift is .3370/.3340 gross valve lift is .572/.567
if I knew then what I know now I would have worked with pat to spec a custom cam of the reverse split variety for them to grind me...and next time that's what I'll do
I understand this, but if he needs to go through comp cams for some discount, and he really wants to save the 100 bucks or so....he can get a 224/224 with similiar lifts on the same LSA and use comp lobes....not a huge issue and it would probably make just about the same power.
Full bolt-on 2000 SS M6 with moser 12 bolt w/4.10's with LS6 intake and tr224/224 .563/.563 112 lsa and have a best of 11.91 with a shitty 60ft. I race big head cam cars all the time and run good against them or beat them. My car is a cam only car also, no head work. I would love to drive a big cam car to see the difference but I have loved my cam for the past two years.
#33
#38
This post made me laugh pretty hard, so I'll give you credit for that.
