Bleeding Cooling system..
I filled up the radiator with dex cool and let the car heat up to half... then alittle over half and it didnt take any of the coolant in.... bad stat or am i doing this wrong??
the waterpump was good before, wasn't weeping and its spinning now.. no coolant leaks anywhere.. inlet tube isnt getting too hot and the other hose isnt hot at all when she's at 210
but did the radiator level go down around the half way mark initially like the stat was opening I really dont want to bust the stat off again but ima do what i have todo
its a 160 hypertech btw.. so it is opening just a little late.. i drained the radiator back into the jug and only got half so it is taking some just has a lot of air as stated... now i got bigger probs though the car has gas in the oil because its so damn hard to keep running due to being untuned (sometimes it will idle @ 800 for 10-15 mins then others it goes to 300 for a few seconds and dies)
http://rds.yahoo.com/_ylt=A0geu6cCcu...c20w%252E%252E
