contemplating this set up
Old Sep 30, 2008 | 07:40 PM
foxriderry's Avatar
Default contemplating this set up
Details Name Unit Price Quantity Total Select
VRX4 (4) Vengeance Racing VRX4 Camshaft $389.00 $389.00
Add ValveSprings to my order: - Comp 928 ValveSprings $158.00 $158.00
Add Pushrods to my Order: - Comp 7.400 (stock length) $114.99 $114.99
PBUDPULLY PowerBond 25% Underdriven Crank Pulley $199.00 $199.00
GM Crank Bolt: - GM Crank bolt $4.49 $4.49
YTUltraLites Yella Terra Ultra Lite Roller Rockers $409.00 $409.00
TimingChain GM LS2 Timing Chain $45.99 $45.99
Mellingoilpump Melling High Volume Oil Pump $149.95 $149.95
36Injector FAST Hi Impedance Fuel Injectors $298.99 $298.99
Select the appropriate size injector for your combination: - 36lb/hr Hi Impedance - -
Grand Total: $1769.41 Delete
its all from vengeance racing, is there anything im forgetting? anything im doing wrong? it will have all the supporting mods, including headers, full exhaust, cut outs, ls6 intake, and mti lid. Im a lot nervous about the oil pump, should i be? any input about porting ure own throttle body?
Old Sep 30, 2008 | 09:07 PM
JPH's Avatar
JPH
Drop the rocker arms and injectors.
Old Sep 30, 2008 | 09:12 PM
jetlag's Avatar
I agree with that guy^^^
Get an ARP crank bolt instead of stock...it's about $20 more, but it's worth it...everything else looks good.
Don't forget shorter belts for that U/D pulley.....Byunspeed was having a deal for $215 for Powerbond pulley with both belts...not sure if they are still doing it, but that would be a better option.
Old Sep 30, 2008 | 10:01 PM
Summerwolf's Avatar
I'd go with the harland sharp stock rocker rebuilds....but since I don't have cores and downtime I'm going with yella terras or the harland sharp myself. I wouldn't buy injectors unless you learned you needed them during the tune.
Also what about lifter trays? If you have a lot of miles its a good idea to replace them.
Old Sep 30, 2008 | 10:57 PM
foxriderry's Avatar
thank you very much for the ideas, and yes it is a higher mileage engine, any things else i should/ could do to prolongue the life while im in there?
Old Sep 30, 2008 | 11:41 PM
jetlag's Avatar
A GOOD TUNE!
I can't stress that enough...I'm not sure where you are located...but don't be afraid to trailer your car somewhere to know it's done right. U-haul can rent trailers and trucks if you don't have one or your friends don't.
It will cost more...but it is well worth it in the end. I know a lot of people who went the cheaper route and ended up getting screwed. So just do your research and use this site..we will all help as much as we can.
Check out the sponsors, and search on here for feedback.
Old Sep 30, 2008 | 11:45 PM
Summerwolf's Avatar
Yeah a full tune is for sure needed IMO after heads and cam, but I see a lot of people getting canned tunes......I just don't quite get that, spend 2000 in parts and not pay the extra 500 for a good tune?
Old Oct 1, 2008 | 10:03 AM
foxriderry's Avatar
yeah, im goin to ttp directly after ... there right down the street, all though there moving, thank god not to far
