patriot heads package
Valve covers = twice - 1) when the valve issue came up 2) to check clearance of the rockers.
Phone calls = made phone calls regarding the two issues above. No more than 2-3 coversations for each issue. Problems resolved VERY easily.
I am not saying I am thrilled about these problems (read my earlier post). What I am saying is that I can accept them (for the most part) and AT LEAST to Patriot's credit, they are handling ANY issue that comes up quickly and to their customers satisfaction. If I wasnt - you all would have heard about it. Hell - SLP knows me and my wheels REAL well
My only acception to your post was pointing me out specifically and making a bold statement that ANY AS or JPR car would show me taillights. I have run my car against other fast cars ON THE STREET (yes ..... illegally - bash me now). I have not put the car on the track or on the dyno. With the several oppertunities I have had to race other fast cars - the results were good. Car felt strong. This is my only means to gain its performance to this point. I have raced plenty of times on the track and I am VERY comfortable my car will put up some numbers.
Dyno time next Saturday - racing at MIR on Oct 4th. I guess that will answer some questions .........
Proofread,
Hannibal <--- capital "H"
HHHHHHHHHHannibal good luck at the dyno, i hope everything works out for the best.
Nothing like owning a bull and a few cows to make steaks likewise nothing like owning a few pigs and billy goats for getting an idea of how bad pig poop smells and how nasty billy goats are when they pee on their chin hairs.
Hmmm I admitt the truth about my heads, it's not pretty I would be very happy to replace them with something else. I spent $1900 including core on them. It was a mistake. Yes, I can freely admitt I screwed up selecting my heads. I'm loyal to sponsors and products that deliver as expected.
There is no need to change your valve seals.I have some new personel since those heads was assmebled.
I know you said you were using diffrent springs since the clearence issues. It looks as if I got the bigger springs, which is what I wanted. Texas speed didn't say anything other than "dual spring" good for .625 lift. I've danced around this subject more than once, but here's the blanket statement:
If you are paying more than $1600 for a set of Stage 2 CNC heads FROM ANYBODY, you're getting raped - and I don't care whose name is on them.
Also another thing to look for, I not saying this can be a problem with patriots but I have seen some issues becuase usually cnc ports are very big to make room for the cutter, that when they cut the spring pocket for larger springs the ports can crack under the spring and leak huge amounts of oil into the intake ports so take a look at the roof of the int port and see if there is a possible crack there
