Wrist Pin Question
Old Oct 8, 2008 | 06:02 PM
Grn4fbody's Avatar
Default Wrist Pin Question
I'm looking into connecting rods for my LS6 build, and I was just wondering what the benefit is (if in) in between the .927 & .944 wrist pin?
Also can I go with the 6.125 over the 6.100..
Also should I beam rods be strong enough for a 200 shot at max?
Old Oct 8, 2008 | 08:47 PM
Grn4fbody's Avatar
Bump, I added more questions
Old Oct 8, 2008 | 08:53 PM
JPH's Avatar
JPH
If this is a N/A motor, I would use a .927 pin and a 6.125 rod imo. Some guys with LARGE N20 and BOOSTED motor applications like the heavier/thicker pins for added strength and a shorter rod to keep the compresion height down, to allow for more material in the upper ringland area. But for your setup, I think .927/6.125 will be fine. Just make sure you purchase "quality parts", diamond/mahle pistons and compustar/eagle rods.
Old Oct 8, 2008 | 08:56 PM
Grn4fbody's Avatar
What about Scat?
It's gonna be a Stock bore LS6 with some 5.3 heads and not a huge shot of N20, also not a massive cam. Maybe a TR224
Old Oct 8, 2008 | 08:59 PM
JPH's Avatar
JPH
What about Scat?
Not a fan of Scat. Buy a mahle piston power pak setuo and a set of eagle rods, machine it, balance it and go spray it.
Old Oct 8, 2008 | 09:20 PM
Grn4fbody's Avatar
Link on that Power Pack?
Old Oct 8, 2008 | 09:31 PM
JPH's Avatar
JPH
just google "mahle motorsports pistons", I don't know the website exactly or have the link man. Sorry. But I use there pistons alot and the are awesome. Good luck with your build man. Let me know if you have any other questions.
Thanks, Joe
