prc 5.3 head cam selection
Old Oct 13, 2008 | 12:08 AM
  #41
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
i hope so i wont to order the combo asap.........
Old Oct 13, 2008 | 12:09 AM
  #42
its kinda of down to 233/239 vs torquer v.3 but i dont want a choppy *** cam is it the low the lsa the less choppier like 114 or is it the less lsa like 111 thats more choppier
Old Oct 13, 2008 | 12:15 AM
  #43
69_YENKO's Avatar
a 111 is going to have a rougher idle then a 114
Old Oct 13, 2008 | 12:25 AM
  #44
so 114 is gonna be smooth and not as choopy
Old Oct 13, 2008 | 12:32 AM
  #45
lemons12's Avatar
correct
Old Oct 13, 2008 | 06:50 AM
  #46
zakk101WS6's Avatar
Get the V3 on a 111!!! You will not be disappointed! Great street cam.
Old Oct 13, 2008 | 09:33 AM
  #47
RedRallyeZ's Avatar
he said he does NOT want choppy though, i have that cam on that LSA and it sounds like a pro-stock car, HARD LOPE
Old Oct 13, 2008 | 10:40 AM
  #48
hahaha nice i im kinda leanin closer and closer to the 233/239 once i get tsp to see how that would work with my set up im gonna order it around thursday or friday
 Michael S. Palmer
Old Oct 13, 2008 | 11:23 AM
  #49
joker_01z28's Avatar
dont know if anyone remembers TSP goes to the dyno, I contacted them about a combo I was looking at that they tested, indiviual results may vary, but ths is what im going with . Fast 92 mm throttle body, Fast 92 mm intake, PRC 5.3 Stage 2.5 heads. 100mm MAF, TSP 1 7/8 inch headers, 228R cam. made 538hp on engine dyno.
Old Oct 13, 2008 | 11:43 AM
  #50
great numbers
Old Oct 13, 2008 | 12:41 PM
  #51
lemons12's Avatar
pro stock..... mmmmhmmmmm lol
ill give jon at TSP right now, he should be able to chime in and help you out..
nevermind, here just call him yourself... tell him everything you want..1 806 866 0734
Old Oct 13, 2008 | 01:00 PM
  #52
dkrvpro's Avatar
Default TSP 5.3 Stage 2.5 with 233/239 Cam
I use this combination on my street/strip 02 Z-28. Stock Short Block, unported 90MM fast, 90MM Nick Williams, 25% underdrive crank pulley,
Kooks Stepped Headers, 4" Mufflex, A4 with PT4000 Yank.
Idles nice at 850 RPM, Pulls good up to 6500 RPM
Very streetable with some chop at idle
Runs 11.60's with 1.63 60' times
Hope this helps.
Denny
Old Oct 13, 2008 | 02:25 PM
  #53
Jon@Texas-Speed's Avatar
Hey guys, sorry for the delay getting in here. We were at the shootout last week and just got back in town early this morning.
For what the original poster is looking for, I would probably go with the 228R cam with the PRC 2.5 5.3L heads. Reason being, the cam will be extremely streetable yet still net you good power. The cam is typically worth a solid 45-50 RWHP over the factory LS1 camshaft and it doesn't sound as aggressive as some of the larger cams on the market. The car will be able to start up, sit in traffic, idle with A/C on, etc. without issues once it is properly tuned. The added compression and smaller 220cc runner of the 5.3L heads matched with this cam will make for a broad, usable powerband which will work well for both steet and stip use.
If you are thinking you might want a little more aggressive sounding cam, I would probably point you in the direction of a Torquer v.3 cam. It too showed very nice results from our engine dyno tests last month. It too produces a broad powerband but will have better midrange and peak numbers than a 228R cam. Also, it will sound more aggressive at idle being you are stepping up a bit in duration as well as the 111 LSA.
Either way you aren't making a bad choice. It will just come down to what you are looking for out of the car. Shoot me a PM or give me a call when you have a minute and I will help answer any questions you have and we can kick around ideas of what will work best for you.
Thanks!
Jon Reynolds
Old Oct 13, 2008 | 07:03 PM
  #54
lemons12's Avatar
sounds about right to me! let us know when whoever was trying to pick a cam decides on one..
just wanna thank you guys at texas speed especially you jon! you have always helped me and anyone i know of to the fullest possible....
Old Oct 13, 2008 | 07:14 PM
  #55
1/4milerunnerZ28's Avatar
I just talked to the guys at TSP and they suggested the 5.3 stage 2.5 with the 228 cam for one of the best street friendly combo around... great lower end power without loosing any top end power...they suggested a 3200 or 3600 vert for the best performance..
Old Oct 13, 2008 | 07:27 PM
  #56
lemons12's Avatar
thats right on man, you will def. turn good times at the track also, not just fun on the street..... id go with the 3600 conv. and 373s with that cam.. but thats my .02..
i like bigger cams, so id go with the ms4 though! haha
Old Oct 13, 2008 | 07:37 PM
  #57
I agree with the 3.73s, and go with a 3600 stall. the 228 with a little bit of tuning is very streetable, but def get a stall as well.
Old Oct 14, 2008 | 10:13 AM
  #58
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The 228R camshaft & PRC 5.3l heads makes great power & is a proven combo for street friendly setups!
Here's a dyno sheet comparing several different heads with the 228R camshaft!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Nov 11, 2008 | 04:05 AM
  #59
DGageSS's Avatar
nice flow sheet. i don't think that TSP talks up the 5.3's cause of the money issue. i saw someone else write that and TSP got pissed and said it wasn't true, although i don't know.
Old Nov 11, 2008 | 04:14 AM
  #60
lemons12's Avatar
that would be me... and me and TSP discussed this........
i still recommend the ls6's..
