LS1 injector in a l92 intake?
Old Nov 12, 2008 | 01:06 PM
JS's Avatar
JS
Default LS1 injector in a l92 intake?
Has anyone used LS1 style injectors in a L92 intake?I would imagine they fit but ar too tall so a LS1 or LS2 rail would be required or could u use the L92 rails with them?I have a set of 65lbers in LS1 style sitting here and the car has the LS1 injector harness so I figured I could use these inj. for the project?
Old Nov 12, 2008 | 03:53 PM
WKMCD's Avatar
I run 42lb Ford Green Tops in my car. They are the same dims as the older style LS1/6 injectors. I do run FAST LS2 fuel rails though.
Old Nov 12, 2008 | 04:52 PM
See5's Avatar
With stock LS1 rails, some tab bending, spacers and 0-rings it can be a very workable low cost deal.
Old Nov 12, 2008 | 05:14 PM
JS's Avatar
JS
Thanks,we did just that and it works just fine....
Guess I'm cheap cheap cheap
Old Nov 13, 2008 | 08:07 PM
RickClarke23's Avatar
Which O-rings need to be used. I guess not the stock LS1 O-rings
Old Nov 22, 2008 | 12:28 AM
LSxPwrDZ's Avatar
What is the demension's on the LS3/L76 style injectors? I know the LS1 style are 60mm from O-Ring to O-Ring. What are all you guy's running with your F-body's and L92/LS3/L76 setups???
Old Nov 22, 2008 | 05:56 AM
See5's Avatar
Lingenfelter has the right o-rings ~$10 plus shipping. You may be able to get them to put them in a cheap envelope or else the shipping is more than the 0-rings.
You can make up rail spacers from al tubing. the spacers need to be ~ 1/2"
Old Nov 24, 2008 | 11:37 PM
89Formulaws6's Avatar
i got my orings from katech, used ls1 style injectors just bent the tabs a little and was good to go
Old Nov 26, 2008 | 02:45 PM
Red Goat's Avatar
Nice setup with the FAST fuel rails and pressure reg - you do know your missing your oil dipstick though right?
I will be running the stock LS2 injectors on the L92 heads - fuel rail just needs a 1/2 spacers to fit without bending the tabs.
