Ls2 Intake?!?
Build plans are CAM, 1 7/8x3in LTs TSP 100mm air lid.
Possible TSP MS4 cam
LS2 intake with TPIS 90mm TB
Now is there any way to ensure that that intake wont leak ill send it out to
LS2portworks if i can get it ported and sealed good if it doesn't coast a arm and a leg and does anyone know the price on this.
I am hunting for 435-450WHP
I have seen the ms4 in a stock car w pacesettler LTs and svo injectors on a SD tune put down 421WHP and 396TQ with a 75mm ls6 intake.....any ideas guys i need some help
As for me haven a ls6 tpis i dont have on i wish i did...
I recently bought a ported LS2 intake done by LS2portworks.com & a BlueMaxx 90mm TB for a few hundred less than a Fast 90 alone. So if it'll get me within even 10rwhp/10tq of a Fast 90 I'll consider it money well spend over my stock LS1 intake.
True to that i feel the same way i just bought a ls2 for alot cheaper than a used ls6 and i willing to give it a shot i wouldn't mind putting it up against the tpis ls6 90mm just for fun to get the real facts but i dont have that kinda money at the time but i do have free dyno time going for me, the only thing i am worried about is its 2 piece design and may leak?....duno how true this is but why would gm design a worst intake they always make there stuff better as time goes on.
Did you have your leak at all?
I don't know if it leaks or not honestly. It's brand new never been installed. I bought it off a buddy local & it came with the Katech kits. I'm very interested to see how it'll perform. I definetly won't have a solid comparison though since it'll be a whole new motor combo, but I'm sure the dyno & track numbers will show how it's performing in the end.
how could the ls1 and ls2 be almost the same there is like a 8yr differance lt1 dave is the one who has gotten a ported ls2 with in 1 hp and 2 tq of an un ported fast 90 and for the price that cant be beat fast is just to expensive unless you can find one around 550
personally id never pay over 600 shipped for one but thats me sheetmetal is only 2k
I would need a link to even begin to believe that a ported LS2 inatke can remotely perform like a FAST. No way it will carry to 7K. I have a ported LS2 now and my final mod will be a ported FAST 92 and I know it will add over 25rwhp with even more under the curve (H/C LS2).
I would go sheet metal if you don't want to spend the cash on a FAST. I would never try to run N20 on an LS2 intake. The main problem with thier 3 piece design is they are vacum'd together and they leak air between the cylinders causing leaner/richer conditions cylinder to cylinder.
Cory (LS2port works) always says ported LS2's are 8-12rwhp from porting only and a FAST "should" add atleast that. You can gain an additional 20-25rwhp on top of that going to a ported FAST. Nothing is cheap in this hobby.
You can make 435 through an LS2 though, so as long as thats your goal, youre good.
Ask Cory if you should go ported FAST or ported LS2....
