Ls1 to Ls3 questions.
Old Feb 7, 2009 | 05:37 PM
bmxer8699's Avatar
Default Ls1 to Ls3 questions.
I had an ls1 motor trans am and now going to an ls3 swap camaro. When i go to buy headers and any other parts for it, I need to buy the ls3 corvette parts correct?
Old Feb 7, 2009 | 05:51 PM
blu byu EH's Avatar
You have to get the F-body exhaust, and anything else depands on what you buy.
Old Feb 7, 2009 | 10:05 PM
bmxer8699's Avatar
so i need to buy ls1 headers then catback etc.
also what oil weight should i run?
Old Feb 7, 2009 | 10:20 PM
108dragon's Avatar
The headers you use for the LS3 are dependant on the vehicle you are putting it in. Not the engine. For the LS3 in FBody swap, use the LS/FBody headers and exhaust. It would be different if it were an LS7 you were swapping as the LS7 has 12 degree heads and may throw header angle off making the exhaust install impossible. But you will be ok with the FBody headers and exhaust.
I'm basically doing the same swap.
Old Feb 9, 2009 | 11:38 AM
jmilz28's Avatar
Check out GMHTP last month and this month (Feb and Mar issues) for a tech article on this very swap. PNs and everything.
Old Feb 14, 2009 | 01:19 AM
UL LOSE's Avatar
Racer
So you guys are saying if I was to buy a LS3 C6 I could use my headers & exhaust that are on my WS6?
Theyre 1 7/8 Kooks,3 inch Ypipe,and GMMG. Would that work on the C6? I think Id have to buy an Xpipe though?
What about my nitrous kit? Its a TNT 78mm Power Ring Kit. Will that work?
Old Feb 14, 2009 | 11:31 AM
formula17's Avatar
No dude,
You use the headers designed for that vehicle, you cant use Fbody headers on a vette.
Old Feb 14, 2009 | 06:12 PM
UL LOSE's Avatar
Racer
Originally Posted by formula17
No dude,
Thats what I thought I just got confused with what they were saying. Wishful thinking I guess haha
