Coils....which are the best....................
Old Feb 19, 2009 | 01:19 AM
LS6427's Avatar
Default Coils....which are the best....................
454ci, pretty aggressive build. Trans Am.
Other than MSD, I've heard nothing but bad things about those from a few people.
Old Feb 19, 2009 | 04:35 AM
LS1MCSS's Avatar
The truck/Yukon coils with the small heat sink on the back of them are the best. They are the D585 coils. Read this article and watch the video.
http://www.megamanual.com/seq/coils.htm
Old Feb 19, 2009 | 04:58 AM
hawkls7's Avatar
On my boosted application we have been using the ls7 coils and just because ive been reading about these truck coils with the resister i had to give them a try , but we did not find any gains with our application . We might have to go with a better spark system like cdi.
Old Feb 19, 2009 | 07:11 AM
LS1MCSS's Avatar
I think you'll probably only see any real gains in a system where you can change the dwell time.
Old Feb 19, 2009 | 07:52 PM
Deeavi's Avatar
I have MSD coils on mine. I have had no problems and they look good!
Old Feb 19, 2009 | 08:44 PM
03 BUSA's Avatar
Stick with your factory setup. Lot of high HP guys are still running the stockers.
Old Feb 19, 2009 | 10:02 PM
Black Sunshine/ 00SS's Avatar
ditto
Old Feb 19, 2009 | 10:06 PM
LS6427's Avatar
What about something like an 800 FWHP 454ci?
Would you upgrade then?
Old Feb 19, 2009 | 10:31 PM
gectek's Avatar
i thought those MSD new multi spark coils were very nice, plus they sell em in a set of 8.
Old Feb 20, 2009 | 05:37 AM
LS1MCSS's Avatar
How many miles do you have on them?
Old Feb 20, 2009 | 08:20 AM
So, somewhere around 700-720 RWHP. I would upgrade to the truck ones, but wont be a big deal if you stick to the stock ones, even at that point.
I know of a few turbo setups that use the truck ones, for better spark, but also a few that also run the stock ones, without issues.
MSD coils had a bad rep when they first came out years ago. I don't know if these issues were addressed, you'll have do a search on them.
IMO, this would be the very last change/upgrade that I would make, as I believe the $ could be better spent somewhere else, especially since any changes or gains are questionable. Good luck.
Old Feb 20, 2009 | 11:55 AM
badpewter-z's Avatar
LS1TECH Sponsor
Stock have always worked fine from what ive seen this includes stock to over 1000hp turbo setups and almost every car thats had MSD's has had issues with them.
Old Feb 20, 2009 | 08:25 PM
DutchmanSS's Avatar
Former Vendor
I am using factory LS1 coils for my Rapid Motorsports built 427.
Old Feb 23, 2009 | 12:00 AM
LS6427's Avatar
How about something that provides a more powerful spark? I read something a couple weeks ago about having a more powerful spark, allowing for a wider gap on the spark plugs for a larger spark, for better burn when it fires.
Is that just a little overkill or really not something worth doing for an N/A engine?
Looks like the truck coils are the way to go just for that little extra, but it would be nice to have a more powerful spark too.
Old Feb 23, 2009 | 03:19 AM
hawkls7's Avatar
without going to a cdi driver with more coil capacity there are spark plugs that produce a more powerful spark . You would have to speak to their tec side and ask for a heat range for your application . their site is .www.pulstar.com
Old Mar 1, 2009 | 08:49 AM
Codefive's Avatar
FWIW ... I made over 900FWHP with my NA 436 using stock LS7 coils with out any issues. The engine turns well over 9000RPM and doesnt miss a beat. I DO NOT use factory cam & crank sensors due to the RPM but he coils work flawlessly.
