active fuel management
Old Mar 17, 2009 | 08:57 PM
shanemilleresp's Avatar
Default active fuel management
just curious has anyone tried or even thought of using a IV motor wiring harness and valve soleniods on an f-body and maybe running a switch for 4 cyl mode??
cus i think that AFM with a t56 and decent rear gears would make for an awesome gas saving car.
any thoughts on how to make it work?
Old Mar 17, 2009 | 09:19 PM
vtirocz's Avatar
I thought about this too! AFM doesn't seem all that effective though on the new camaro, given that the manual (non-AFM) version is rated at 16/24mpg and auto (w/ AFM) is rated at 15/23.... (i think those fuel economy figures are accurate). I think it could be optimized though for some pretty significant gains. I'm interested to see if anyone has tried this on a manual.
Old Mar 17, 2009 | 09:22 PM
yeah well that 23 mpg is with a .69 OD and in a 3900 lb car im sure in a 3500 lb f-body with .5 OD would benifit more
id really like to see someone put that on an fbody
Old Mar 17, 2009 | 09:46 PM
SweetS10V8's Avatar
There is probably a reason only autos get AFM and manuals do not. All though I have no clue as to why, anyone??
Old Mar 17, 2009 | 10:53 PM
because most customers want a seamless "shift" into 4cyl mode, they unlock the conv. for a sec switch to 4 cyl mode then lock it again
with a standard it would be very rough unless the computer controlled the clutch, but i dont care about rough shifts
Old Mar 19, 2009 | 02:06 AM
Pauls325's Avatar
you would have to use an ls4 manifold to make it work along with the valley cover the manifolds are very restrictive because of a u bend right behind the throttle body for an oil line to the valley cover and the lifters i get about 18/30 when it comes to mileage
Old Mar 19, 2009 | 02:51 PM
Ragtop 99's Avatar
Originally Posted by shanemilleresp
yeah well that 23 mpg is with a .69 OD and in a 3900 lb car im sure in a 3500 lb f-body with .5 OD would benifit more.
What's the rear gear on the A6 Camaro? 2.56? 2.73? It is probably not as big a difference as just looking the OD would suggest.
