Drive by wire reliability
Old Apr 4, 2009 | 11:39 PM
org's Avatar
org
Default Drive by wire reliability
I have a L92 crate engine an wonder if anyone has experienced any problems with the DBW throttle setup. I'm looking for absolute reliability (not possible of course, but want to eliminate as many factors as I can) and am looking to compare cable and DBW.
Thanks.
Old Apr 6, 2009 | 09:29 PM
Domsz06's Avatar
my Z06 is drive by wire and it's amazing.
Not one issue, not sure if this helps... just wanted to chime in.
Old Apr 7, 2009 | 06:44 PM
bonestock99's Avatar
If there were any issues with dbw don't you think car manufacturers would have changed back to cable by now? I mean its only been 10 or so years! LOL
Old Apr 8, 2009 | 09:18 AM
1lejohn's Avatar
The only issues I know of are from bracket racers who complain about the cosistency of them on their lights and 60' times
Old Apr 8, 2009 | 09:27 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
Every LS vette has had Drive By Wire. They have a redundant sensor system on the pedal that uses 2 or 3 sensors to make logic checks to make sure the setup works correctly. Durability is no problem. There have been a few bad TAC modules before, but people normally replace them every day just because they do not understand how they work.
Old Apr 9, 2009 | 03:04 AM
org's Avatar
org
Actually, I doubt GM would be as concerned about ABSOLUTE reliability as I am. I'll be trusting the only body I have to the engine. GM is more concerned about the cost/benefit ratio, not absolute reliability. As long as they think something results in more $ overall, they'll stick with it even if there are a very small number of problems. Based on that, I think my question is valid.
Old Apr 9, 2009 | 03:07 AM
org's Avatar
org
Thanks, John. That's information I can use. I had no idea how they were built.
Old Apr 9, 2009 | 09:19 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
Also, contrary to popular opinion, the automakers do have the interests of the end user in mind and durability in mind whenever they go to even formulating an idea for a new part. Even if they make a "cheap" part, if you have to replace that part every month under the warranty coverage, it is no longer "cheap" for them anymore.
Old Apr 9, 2009 | 10:44 AM
org's Avatar
org
I probably wasn't clear...I agree with you, that's why I said "cost/benefit" ratio. If the part doesn't at least provide an acceptable level of reliability, it then isn't cost effective (even if it's free), since it drives customers away and costs the company too much for warranty work. There has to be a level that's somewhere short of absolute reliability that's "good enough" though. I suspect drive by wire exists partly because of costs, partly because of drivability, and possibly partly for emissions.
Next question: what will it take to make a LS3 GMPP engine controller work on my L92? This is something I asked some time ago, but nobody had a definite answer. Is there a L92 controller on the horizon?
Thanks
Old Apr 9, 2009 | 10:50 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
The only diff really in the L92 is the fact that it uses the VVT system. If you unplug the VVt phaser then it will run fully advanced i believe. Then you can use the rest of the engine without any problems. Comp Cams also has a phaser blocker that will limit the amount of movement the cam will have, which would stop it from going fully advanced if unplugged. Then you can use the LS3 controller. I do not know of an L92 complete assy controller on the horizon, but new things happen all the time. You may want to ask Mast Motorsports, as they have alot of that tech down.
Old Apr 10, 2009 | 12:03 AM
org's Avatar
org
Thanks John. Another question: It sounds like failures are very rare for the DBW, but when one occurs, what happens? Does the engine continue to run with poor throttle response, or does the computer shut it down completely?
Old Apr 10, 2009 | 06:43 AM
reduced engine power or limp mode
Old Apr 10, 2009 | 07:17 AM
irocbsa's Avatar
I used to do ETC validation work for GM earlier in my career before I became a calibrator. The ETC system is incredibly reliable and secure. As someone said about, there are two sensors on both the throttle and the pedal. One sensor has a positive voltage vs. position slope and the other has a negative slope. They are both checked continuously against each other for rationality and will cause a fault if the values don't correlate.
If a fault occurs (of which there are about 35: opens) the system takes one of two default actions: it clamps the maximum throttle position that you can command (reduced engine power), or it defaults the throttle to a given value and manages the incoming air by shutting down cylinders (limp home mode). The second default action feels quite nasty but it will get you home. I wouldn't be concerned about using it. The only drawback is the extra wiring under hood that you'll need plus the addition of pedal position sensors.
Old Apr 10, 2009 | 07:19 AM
SweetS10V8's Avatar
I love threads like this, OP asks a question then argues with a common answer. If you have your mind made up, why post?
Why do you want to disable the phaser?????? I would kill to have one.
Phaser limiters reduce the amount of retard that the phaser can adjust. No matter what, if you just unplug the phaser it will sit fully advanced in the park position. Then you have to deal with differences between cam that are made for phasers and ones that arent(big advance differences). Youll have to swap to a traditional timing chain and cover setup so you can run any aftermarket cam.
Old Apr 10, 2009 | 10:06 AM
org's Avatar
org
Uhhhh....are you sure you read the thread? Nothing asked about phasers at all. You seem to be looking for an argument that doesn't exist. In fact, there have been no arguments at all in this thread, just some pretty good information. Thanks to all.
Old Apr 10, 2009 | 10:08 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
you were talking about the controller for the L92 which has the phaser on it. NO apparently he did not read the thread, because he reiterated almost everything i posted.
Old Apr 10, 2009 | 10:28 AM
org's Avatar
org
All true, John, but I didn't ask about the phaser, only the DBW and later the LS3 controller. We had discussed the phaser in an earlier thread and you kindly gave the info I needed then. By the way, your delivery was much better than his:-) Thanks again for the information. It's a help in deciding which way I'll eventually go. I know it might seem strange that I'm so concerned with failure modes and so forth, but this engine will be on the front of an aircraft, so I'm pretty interested in eliminating any possible failure points that I can.
Old Apr 10, 2009 | 10:36 AM
y2khawk's Avatar
I concur with that. I did a stint as an ETC calibrator for 900 trucks before I left GM a couple years ago. There is ALOT of security redundancy in the ETC system, without going into a ton of detail there's alot more than just opens and shorts for the sensors that will cause the ETC system to take a default action.
And there are various ranges of action from simply a reduced pedal map, to managed toruqe, to forced idle, to complete engine shutdown. A walk home situation is the last option, and over all driver security is the main concern.
Sure GM may have some cost issue in mind at the higher levels, but there are real bodies doing the work. The lawyers keep us safe
Old Apr 10, 2009 | 10:39 AM
Beau@SDPC's Avatar
LS1Tech Sponsor
Well that being the case, it def would make a diff. Everything is diff in the air. I would prob use a cable driven TB, take the VVT off of it and run it normal LS2 style, and run an ign controller from MSD. Thats all you need. put a carb on it and call it a day. Would be the easiest, but if you want to stay with fuel injection, then rest assured that GM has thought about what ifs, that is why they have so many checks. Use the way that will make you feel the safest.
Old Apr 17, 2009 | 01:51 PM
1lejohn's Avatar
Check Mast Motorsports for a contoller for the L-92
