Corvette Power-steering pump
Old Apr 24, 2009 | 02:53 AM
Morten_LS3_R32's Avatar
Default Corvette Power-steering pump
I was trying to fid what connection I need on the powersteering:
-6 AN (16mm x 1.5 O-ring Seal) Power Steering Adapter
-6 AN (male to 5/8"-18 O-ring seal) Power Steering Adapter. Clear anodized
-6 AN (male to 11/16"-18 O-ring seal) Power Steering Adapter. Clear anodized
Witch of these will fit the outlet port of the Corvette Power-steering pump?
Its a 2008 Corvette setup, LS3 engine and accessories.
Old Apr 24, 2009 | 10:34 AM
VGLNTE1's Avatar
I am almost certain when i hooked up my PS pump, the lines had a O ring on them....
Old Apr 24, 2009 | 10:44 AM
Hi!
Thanks, but there are three thread types as mentioned above that could fit, with O-Ring, and I wonder which thread will fit?
I believe that it is 16MM, but I need to confirm this.
Old Apr 25, 2009 | 06:38 PM
VGLNTE1's Avatar
Originally Posted by Morten_LS3_R32
Hi!
hum, well heres a bump for ya...im not sure. Maybe call a dealership?
Old Apr 25, 2009 | 09:08 PM
405HP_Z06's Avatar
I measured a spare pump in the garage. The high pressure side at the pump is an M16 x 1.5 o-ring. An example of the fitting for this application is:
Russell Performance
Part # 648060
Description: -6 AN (16mm x 1.5 O-ring Seal) Power Steering Adapter
Or
Earl's
Part # 991955
Old Apr 26, 2009 | 08:31 PM
VGLNTE1's Avatar
Russell Performance
Part # 648060
Or
Earl's
Part # 991955
man you gotta love the info you get from good members on forums
Old Apr 28, 2009 | 09:12 AM
1969 CON's Avatar
I found this topic when I was looking for a solution for connecting a corvette power steering pump on an LS2 swap I am doing. I am putting an LS into my 69 chevelle. I went with the factory front drive accessories for a vette. I learned that I would need an adapter made because of the clearence between the 6AN adapter and the pully on the ps pump. I visited a local aircraft / performance products store and we came up with a solution. We used a power steering hose from a 2002 Pontiac Firebird and cut off the 16mm side making it a 90 degree angle. We attached the 16mm side to a male thread (6AN) fitting. I had another pressure line made and hooked it up. This solved my problems. Just using the 6AN adapter (like the russell or earl's) did not give me enough clearence. The Firebird ps hose was $20 from Autozone (duralast part #80229) Hope this helps. (I tried to attach some pics but was having problems)
Old Apr 29, 2009 | 11:06 AM
Russell Performance
Part # 648060
Or
Earl's
Part # 991955
Hi!
Thanks for the fast and precise reply! I have ordered the Russell one yesterday...
I do not have that clearance issue, I think... Looks like I can use the adapter and a straight AN-06 connector and hose, but if it don´t fit, I will try it your way. Thanks for the tip.
Old May 1, 2009 | 08:45 AM
koolrayz's Avatar
subsribing
Old May 3, 2009 | 12:48 AM
405HP_Z06's Avatar
Great info, thanks!
Old May 9, 2009 | 03:48 AM
racecar's Avatar
I used an 86 Corvette steering rack in a SCCA Trans Am car. Same fitting and Aeroquip hoses, works great.
Old May 28, 2009 | 09:34 AM
I just wanted to inform that I have mounted the harware on the Powerstearing pump, and I used the following:
RUS-648060 #6 TO 16MMX1.5 O-RING SEAL
RUS-620401 ENDURA HOSE END #6 STRAIGHT
RUS-632618 Russell PowerFlex Power Steering Hose
And it worked perfectly, here is a picture:
Old May 28, 2009 | 03:17 PM
405HP_Z06's Avatar
Happy to see it worked out!
Old May 28, 2009 | 09:52 PM
1969 CON's Avatar
Good deal! Glad to see that you got it to work!
Old Nov 19, 2009 | 11:28 AM
hotrod44_4u's Avatar
i have a 98 z28 camaro ls1 and doing a engine swap to a 2004 ls6 corvette motor, but have a prob finding the right power steering hoses pressure and return? does anyone know what hoses needed?? part # any info needed
Old Feb 18, 2011 | 12:39 AM
bmf5150's Avatar
Great info!!does the return from the gear box go into the reservoir ?what hose u guys use there?my setup is from a 97 ls1 into a 68 camaro
Old Mar 4, 2011 | 12:31 AM
jalper's Avatar
Restricted User
Mine was the O ring style on my pump, Have you tried a KRC pump they come ready to rock and roll for about $170.00
Old Sep 3, 2011 | 08:47 PM
81cuttysupreme's Avatar
i have a little different question about the same pump. the inlet on the pump, is close to my steering box. i have a conversion vehicle with a procharger. It appears to be pressed in to the pump housing. Has anyone pulled this fitting out and replaced it with a 90 degree elbow? the tube has a 45 already, but i figure if i try to pull it out turn it and put it back in, there is a chance I will damage the tube. well, i'm kind of stuck on this issue for now, so i would greatly appreciate any help or ideas. also does anyone know where i might be able to find a pressed in 90 fitting?
Old Sep 4, 2011 | 07:22 PM
S10xGN's Avatar
Don't see how this is possible with a Corvette pump, as the pump inlet is on top between the alternator and water pump (see arrow).
Old Sep 4, 2011 | 07:51 PM
right. however since i'm running a procharger the ps pump is clocked so that the inlet is at the 3 O'clock position if your standing in front of the engine. I swear i saw one that had a inlet with a 90 degree bend, i'd like some insight though before i go tearing up a perfectly good pump. has anyone pulled out this pressed fitting? how? I tried the hammer method a little to no avail. help?
