LS2 coil boot/terminal p/n number and crimping tool
Well its an easy one but i was unable to find it on the net.
I got a lt4 with a ltcc kit that work with 8 ls2 coils.I ve installed everything and cut my plug wire to the good length.A member gave me a taylor number for the coil boot/terminal kit but i realise when trying to install them that they where not the good one...
Also that my simple cheap crimping tool sucks big time so...
Does anybody know whats is the good p/n number (msd,taylor,accel..) for the coil boot/terminal kit.
Also would need a good crimping tool that could work with my case.
Thanks a lot.
Thanks a lot.
I can set you up with some MSD coil ends and boots. Did you get the blue handle crimping pliers from Taylor?
http://estore.websitepros.com/2120533/Detail.bok?no=77
3304 is the MSD part number for a 2 card of the coil terminals and boots or I can set you up.
They will cost you 37.79 from Summit delivered for 8 of them plus 15.69 for the crimpers.
OR I can set you up for less
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yes I already got this crimping tool and it sucks big time.I would buy the big professionnal ratchet one from msd if i was sure that it work well for the application.
Also i would be more than interested in the GOOD ls2 coils boot/terminal kit.
Send me a pm.I need this quick.
By the way for your info i ve receive the small 3/4 inch spacer that was missing in my LS2 coils brackets kit.Thanks.
Eric
Eric
