Introducing Stage 2 Intake Porting
Old Sep 5, 2009 | 01:41 PM
JeremyF's Avatar
LS1TECH Sponsor
Default Introducing Stage 2 Intake Porting
Stage 2 LS2/3/7 intake porting
While the intake manifold is more often than not a restriction in the induction we aim to make it as little of a restriction as possible. All of our typical stg 1 LS2/3/7
manifolds are ported to about 93mm, or 3mm larger than the stk TB flange opening. Our ported FASTs are closer to 95mm but they are over 94mm. This is all in the interest
of most gross flow at the entry and most plenum volume. Typical stage one manifold porting is very extensive and time consuming to port correctly. We remove a very
substantial amount of material from the plenum, TB flange, and runners. We offer the most aggressive porting for the dollar and strive to go the extra mile in all that
we do: porting, tuning, and installs.
We avg over 11rwhp and 13rwtq from our base Ls2 manifold porting with over 420 LS2s to our credit, 95+ LS7 (18RWHP and 20RWTQ), 60+ LS3 & L76s (12RWHP and 15RWTQ) and over 400 TB's.. We were curious as to how far we could take the manifold by really opening it up to the next level and taking a page out of the FAST/Wilson notebook...
Stage 2 porting is taking the manifold to its limit - as much of the plenum is removed while still staying safe from vacuum leaks, which takes about twice the time to port.
The FAST manifold utilizes as much plenum volume as possible within the space requirements - the larger the air reservoir the less likely it is to deplete it at medium and high rpm. Hence the difference from an LS1 to an LS6 manifold, plenum volume. (We have tested this manifold swap many times for an avg gain of 10RWHP and 10RWTQ; again plenum volume.)
We rework all the runners for an even deeper cut and we use a much more aggressive sanding method, even deeper than the 8 inches we typically port in the stg 1 manifolds. For stage two manifolds we remove the inner posts and completely flatten the plenum floor all the way to the back on the inside of the manifold as well as the outside so as to make a sort of air gap between the valley and manifold base. We epoxy small aluminum plates, screw them in, and then epoxy the inside as well, to prevent any air leaks. This stage 2 manifold porting is a cheaper alternative to a FAST manifold, but it is also designed for someone that is trying to FULLY optimize their power on a budget. We are targeting those that want the MOST from the stock manifold at a decent price.
On our own GTO we tested the stage 2 manifold vs our stage one and we picked up an additional 6rwhp and 7 rwtq on an A-B test on the dyno same day, same weather, same engine conditions. This is in addition to the 11/13 from the stage one manifold We also had an independent test done by a shop in NY and they gained over 15+rwhp and 18+rwTQ.
We do not offer stg2 for the FASTs. We port all of them as aggressively as possible over 3.5 hrs per manifold.
Stock opening:
Stage 2 opening:
Stock floor:
Stage 2 floor
Stock Floor:
Stage 2 floor:
Stage 2 on the top, stocker on the bottom:
Stock:
Stage 2
The Stage 2 manifold pictured here has been on our GTO for the last year with out any problems what so ever. It is after this long term testing and dyno proven results that we are proud to now offer this power making manifold for $375.00 (like all of our manifolds, on an exchange basis). These are for LS2, LS3 and LS7 manifolds. We do not port the LS1 & LS6 manifolds, as we have not seen any measurable gains from porting.
Old Sep 5, 2009 | 08:34 PM
1999vetteroo's Avatar
What's the estimated turn around time?
Do you do a core charge?
Nice write up!!!
Old Sep 6, 2009 | 05:22 PM
VortechC5's Avatar
Have you tested a Stage 2 L76 on a big inch engine? I have a LS7 based 427 with L92s on it. I may need to so this...
Old Sep 8, 2009 | 11:45 AM
raymond mckinney's Avatar
He tested on my freinds full bolt-on 08 Vette and gained 10rwhp.
Old Sep 8, 2009 | 12:42 PM
Dutchman427's Avatar
Mine will be on its way down tomorrow Jeremy. Thanks
Old Sep 18, 2009 | 03:11 AM
Spectre86's Avatar
Nice write up!!!
x2
Old Sep 18, 2009 | 07:38 AM
JeremyF's Avatar
LS1TECH Sponsor
The turn around time is typically 2-3 business days if you send your intake and tb to us. If you cannot send your intake, the core charge is $550 which will be refunded to you when we receive your stock parts back
Shalane F
Old Sep 26, 2009 | 08:55 AM
JeremyF's Avatar
LS1TECH Sponsor
Can't wait to hear how everything works out and nice talking with you yesterday.
Dan
Fasterproms
Old Oct 2, 2009 | 04:25 PM
JeremyF's Avatar
LS1TECH Sponsor
We have been receiving requests to purchase LS2 Stage 2 intake manifolds outright and we now have a limited number available, they can be purchased for $550.00 shipped in the lower 48. We also can sell the Stage 1's for $475.00 shipped.
Thanks
Dan
Fasterproms
Old Oct 3, 2009 | 08:05 PM
c5racr1's Avatar
can you do stage 2 porting on a ls7 intake?
Old Oct 3, 2009 | 08:17 PM
yes they can. I just recieved mine.
Old Oct 4, 2009 | 06:50 PM
PM sent
Old Oct 5, 2009 | 09:30 AM
JeremyF's Avatar
LS1TECH Sponsor
These are pictures of the just finished LS7:
Throttle opening
Throttle opening
Floor
Intake runner
Intake runner
Old Oct 5, 2009 | 10:14 AM
That intake looks familiar.
Old Oct 5, 2009 | 10:16 AM
JeremyF's Avatar
LS1TECH Sponsor
It ought to, lol!
Old Oct 5, 2009 | 12:44 PM
adam205348's Avatar
Just curious, have you pressure tested the intakes for possible issues with Boosted applications?
Old Oct 10, 2009 | 01:15 PM
JeremyF's Avatar
LS1TECH Sponsor
That we have not been able to do, just a long term test on our test car (one year on the GTO)
Old Oct 10, 2009 | 01:16 PM
JeremyF's Avatar
LS1TECH Sponsor
Here is a helpful tuning tip post for those doing there own tuning, or having others doing the tune:
https://ls1tech.com/forums/pcm-diagn...folds-tbs.html
Old Oct 11, 2009 | 11:49 AM
smokin91rs's Avatar
Default ls3
i home ported my ls3 intake manifold modeled after the stage 2 and it now howls like wind blowing around the house(not a whistle) i have sprayed brake cleaner around and had the intake off agian and can not find any leaks. does anyone else have this? most noticable at idle and reving of even crusing. im running a lg motorsports g6x3 cam my map reads 70-72kpa at hot idle 950rpm. do i mabye have a internal leak, in the roof of the intake into the runner
Old Oct 11, 2009 | 04:00 PM
themack56's Avatar
why dont u offer stage 2 on fast intakes?
