LS3 MAP sensor and LS1 wire harness???
Old Sep 14, 2009 | 05:16 PM
ss.slp.ls1's Avatar
Default LS3 MAP sensor and LS1 wire harness???
I am going to be using a LS3 intake manifold and I was going to get a new screw in style LS3 map sensor from the dealership, but is it compatible with a LS1 wire harness?
Help is greatly appreciated.
Old Sep 14, 2009 | 05:52 PM
Jditlfm's Avatar
No its not and even with the conversion harness It did not read the right readings. I used a ls1 map sensor plugged that front hole and used vacuum line off the back. No problems since. I speak from experience of chasing that problem down from people telling me it would work.
Old Sep 14, 2009 | 05:57 PM
ss.slp.ls1's Avatar
Originally Posted by Jditlfm
No its not and I even with the conversion harness I did not read the right readings. I used a ls1 map sensor plugged that front hole and used vacuum line off the back. No problems since. I speak from experience of chasing that problem down from people telling me it would work.
That's just what I'll do...Thank you very much!
EDIT: What did you use to plug the map sensor hole?
Old Sep 16, 2009 | 08:35 PM
arwokc's Avatar
Will the LS3 MAP work with the LQ4 6.0L setup with L92 heads and LS3 intake?
Thanks in advance.
Old Sep 26, 2009 | 07:25 AM
frankmarroquin's Avatar
Jditlfm By anychance do you have some pics?
Old Sep 27, 2009 | 02:36 PM
Jditlfm's Avatar
I do not have any pics of this i did it with the intake all ready on the car. I just made a T with the hvac vacuum line so i could have both off the back of the intake.
Old Sep 27, 2009 | 03:05 PM
raymond mckinney's Avatar
I glued my Ls1 sensor in the back and pluged off the front hole, quick and easy fix.
Old Sep 28, 2009 | 02:17 AM
ss.slp.ls1's Avatar
Plugged it off with what?
Old Sep 29, 2009 | 05:52 PM
I used a bolt and put sealer on it. You cant even see it with the throttle bracket and linkage on.
