What horsepower can stock LS3 injectors support?
I'm building an L92 headed LQ9 for my IROC, and the LS3 intake/rails/injector take-offs on Ebay are looking pretty appealing. What kind of horsepower levels can the stock LS3 injectors support? My goal for the engine is 450-ish RWHP.
im in the same boat as you. also interested to know.
Formerly darynC-10/23/10
my truck makes 458rwhp and 435rwtq . using a 230-242 size cam stock truck intake manifold . and bolt ons.... @ 6100 my injectors were at 91% and 6700 they were at 102% using a lenient 18% drive train loss even with 22'' wheel's my motor makes around 540hp and 513tq at the crank ..
so we can just say anything over 550 at the crank ur asking for trouble!
dunno if this helps but theres my 2 pennies
Bringing this back to the top in hopes of getting some realistic numbers. I see a lot of RWHP cam-only C6s, but my 403 LS3-headed stroker may be a bit above that number. What horsepower can stock LS3 injectors support?
My combo with ls3 injectors made 520rwhp through a stalled auto at 95% duty cycle and stock fuel pump .. Then made 550 rwhp with stock fuel pump but upgraded to zr1 injectors but still at 92% duty cycle it that helps...the 550 was with new exhaust and vacuum pump...
I don't think you were looking at the best data a couple years ago when the LS3 was a much newer engine than it is now. Like DietCoke said, they have LS7 injectors on them, it's not like the days of the LS1 4th gen, when a 1999-2000 LS1 car was just about out of room in the fuel department once it had bolt ons.
See, that's why I'm confused. SweetS10 had an 80% duty cycle at 400wrhp, and DietCoke had 500RWHP at a 72% duty cycle. What makes SweetS10's motor so much less efficient that it needs way, way more injector (comparatively)?
I just sent my stock Ls1 fuel injectors resized by stiegemeier porting ( yea I know they do a lot of ford stuff) but they also do a lot of Fuel injection services and they resized mine to 63lbs for my application. Not bad for 175 bucks. IMHO so if your having doubt I'd just resize instead of buying newer or bigger and used stuff.
