l76 map sensor ??
Old Nov 3, 2009 | 11:32 AM
blackbyrd's Avatar
Default l76 map sensor ??
i ahve the l92/l76 combo on my 414 setup and i had made due with an old map sensor from a ls1 setup and a bracket i fabbed up, but now that teh ecm is giving me map codes without looking further into im probably going to just replace it as im sure its not sealing as well as it should.
so my question is can i just get a ls3 map sensor and plug it up to my ls1 wiring and ecm?? or is there an other option.
thanks in advance
Old Nov 3, 2009 | 08:35 PM
blackbyrd's Avatar
anyone??
Old Nov 4, 2009 | 06:10 AM
69LT1Bird's Avatar
The connector is different. Why not just replace it with another LS1 style?
Old Nov 4, 2009 | 11:42 AM
blackbyrd's Avatar
the l76 one is in a different location and mounts different
the ls1 map clips slash plugs into place and is in the back
the l76 has a tab and a hole for a bolt to go through it and is behind the throttle body.
unless they make a ls1 map that bolts on like the l76.
Old Nov 4, 2009 | 12:35 PM
rojs234's Avatar
Don't know if this will help. I have included a picture of the map sensor that was in my L76 manifold, (which I have since sold) It was the one you mentioned that fit just back of the throttle body. In case you can't read the part #, it is Delco #16212460. I'm sure it will interchange to a parts store #.
Hope this helps. Ron
Old Nov 4, 2009 | 12:47 PM
blackbyrd's Avatar
that is the style sensor i have now, but my manifold has a bolt hole to hold it in place instead of the the clip tab like the one you have pictured
Old Nov 4, 2009 | 12:48 PM
69LT1Bird's Avatar
ACDELCO Part # 12614970 {replaces 213-331 #16212460, 213331}
Category: Manifold Pressure (MAP) Sensor
The 2002 LS1 F car uses the same sensor. 12614970 is the F car part number.
Old Nov 4, 2009 | 12:49 PM
blackbyrd's Avatar
this like what i would need unless that is a bracket and not the sensor
69LT1Bird's Avatar
That means you have a LS3 intake manifold, not a L76.
MAP SENSOR 12591290 213-3842 has provisions for both a bolt and snap in design.http://cgi.ebay.com/ebaymotors/MAP-S...31810003r28030
Old Nov 4, 2009 | 12:51 PM
blackbyrd's Avatar
the outside of the intake runners on mine are not rough like the ls3 and i got it nearly 2 years ago was the ls3 even availible then?
Old Nov 4, 2009 | 12:55 PM
69LT1Bird's Avatar
The acoustic cover and bolt in style MAP are dead give-aways. Model year 2008 was the first year so they were available in 2007 calendar year.
Old Nov 4, 2009 | 01:03 PM
blackbyrd's Avatar
any other way to idnetify them i dont have the cover , i got it from a member on here when i was building my setup for 175 bucks and was told it was an l76 so thats why have been saying that,
and i missed the link you put to ebay can i use that sensor with the ls1 ecm?
Old Nov 4, 2009 | 01:04 PM
rojs234's Avatar
I can't say for certain since I don't have the manifold anymore, but I seem to recall that it had an extra bracket that the MAP snapped onto, but I am certain that mine was an L76 and it was new and that is/was the MAP sensor. It is the same as an LS1 and I still have it and use it on my MSD 6010.
Old Nov 4, 2009 | 07:07 PM
blackbyrd's Avatar
ok so now i just need a for sure answer can i use the ls3 map on my ls1 ecm, i know the connector is different, so next question can i modify my connector to use it? or do i need to fab a bracket that works much better
this all started cause im throwing a map code, and im starting at the obvious
Old Nov 4, 2009 | 07:28 PM
69LT1Bird's Avatar
Internally they are the same 0-5V system, you will need a new connector to use the LS3 MAP. Go to Rock Auto dot com and you can find the MAP and connector.
Old Nov 4, 2009 | 08:39 PM
blackbyrd's Avatar
thank you very much
Old Feb 3, 2010 | 09:47 PM
the jester 812's Avatar
if i buy the connector and map sensor can it be spliced into the ls1 harness since it uses the same 1-5 volt reading?????
