Anyone use the SLP crank pulley?
good piece? I was wondering if it is as good as quality as Powerbond. Speed INC sells SLP, I dont see PB, and id like to have one ASAP. thoughts?
Right. The SLP is a re-boxed Powerbond pulley. We have run through a LOT of them without an issue at all. I would say the Powerbonds are probably the most popular brand pulley we sell. Let me know if you need one. We have them on the shelf and ready to go! We price match as well if you find it cheaper somewhere else as well!
Jon
Jon
It's worth mentioning that the TCI is identical as well, and a bit less expensive than too! Side by side, you can't tell the difference (other than the TCI is painted black and the Powerbond is not painted).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Correction: The Powerbonds are now black as well
__________________
__________________
Even the ARP bolt is now just stock length. They don't make it longer anymore. There are a few write-ups floating around on here about how to make an inexpensive pulley installer using Home Depot items though, which can save you some headache and frustration!
__________________
ok, i have that thread in my collection on here,, i know exactlly what your refering to...
https://ls1tech.com/forums/generatio...t-problem.html
Perfect, that one VetteNuts posted is great!
__________________
