FAST 102mm manifold: Painted!
Austin, great price on the paint work!
Since I wanted a more stealthy appearance, I used Rustoleum Satin Textured (spray can from Lowe's @ $4.79
) for a paint texture that emulates the original granular finish on the manifold's top.I washed the top in warm dish detergent, rinsed it off in warm water and dried it with compressed air. I laid it on a rack in the sun to warm it up a bit, then sprayed it while it was still warm. After allowing it to dry overnight, I added another coat.
It seems to be a really durable finish.
Damn man, you suck! J/K! Your manifold came out great! It looks really good. I guess the moral of the story here is, live and learn, and don't be afraid to try something yourself...Thanks for posting that up for everyone else, so they can do it and save a bunch of $$.
Later!
Later!
I would be apprehensive about rattle canning a nearly $1000 intake myself.
Just ENJOY the damn thing, hahaha
I purchased one last month and am going to have my builder paint it.(or now look into powdercoat!)
After spending that kind of coin for a manifold and then cover it with shaker can paint- well, I just can't do it.
The painting expense that I saved paid for my Powrmax MAF and new intake setup. Although it's a matter of preference, I don't spend a lot on cosmetic stuff. If it doesn't produce results, it's not there.
In the end, what counts most, though, is that you are happy with it.
In defense of Katech, labor is not cheap, especially at their level. It took some time to disassemble, prep, paint and reassemble the manifold. I'm certain that it's a quality job and that you won't have any problems with it.
Well said Carl. Thanks again!
Some of you guys really have no idea what it takes to properly prepare and paint. Kudos for doing it for under $300 to Katech !
method and they have no trouble with cure heat of 350ish.
The FAST's are made of different type of plastic and the top shell is quite thin and a different material than bottom pieces. It will not take 350 degrees according to FAST.
FYI I charge $180 shipped to coat them, and that includes either having the letters done in an accent color and then the intake cleared, or shaving the letters off.
Plenty of pics in this album on my site
http://thepowderpro.com/gallery/?level=album&id=5
