What else do i need to install long tube headers
Old Jan 19, 2010 | 11:57 AM
kb274868123's Avatar
Default What else do i need to install long tube headers
What else do i need besides the headers (of course) and tools? Do i need a new cat and Y pipe or can those be adjusted to fit the new headers. Also what headers are the easiest to install? I dont have a lift so any advice will be helpful.
Old Jan 19, 2010 | 12:01 PM
baalic's Avatar
pretty self explanatory but header gaskets if your don't come with them. and if you running with stock manifolds, if you dont want to change the ypipe , you will probably want to go with shortys...... with LT's you will definitely need a new Y or have to be pretty good at re fabricating the one you have...
Old Jan 19, 2010 | 03:23 PM
5LTRETR97's Avatar
Do you already have the longtubes? You will definitely need a new y-pipe. If you need one I might be doing a true dual set-up so I might not need my kooks y-pipe. Let me know. My kooks were not that difficult.
Old Jan 24, 2010 | 06:05 AM
the_merv's Avatar
Veteran: Air Force
Get the Copper Header Gaskets. I vote for TD's..
Old Jan 26, 2010 | 09:23 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Give us a call, we offer complete packages that will give you all the parts you need for the install. headers, y pipe, o2 extensions, etc... We have it all in stock & can get you package pricing!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 26, 2010 | 11:48 PM
smok'nZ's Avatar
MASS seller approved
aftermarket y pipe gaskets is all i needed i alredy had 02 extensions tho
Old Jan 28, 2010 | 04:58 PM
f-bodyguy's Avatar
and gor the tips....remove the spark plugs...alot of people dont...when doing the driverside jack up on the driverside of the motorand it will slide right in from the bottem...good luck
Old Jan 29, 2010 | 07:59 AM
willizm's Avatar
^How high should I get the car off the ground? I'm doing my ARH header+catted Y install this weekend and have gaskets and O2 extenders. I thought I heard somewhere before that you should remove the starter on the passenger side to give you a little more clerance.
Old Feb 4, 2010 | 04:00 PM
01Pontiac's Avatar
small arms and small hands help. lol
